Question about Gaggia Classic Brushed Stainless Steel Espresso Machine
Watery espresso (puck?)
I have a five year old Classic that has served me well but recently has been leaking from the group head, producing watery espresso with little or no crema and very recently when heating the milk it sounds like pebbles are being shot into the milk - the milk is heated but no froth produced.
Any suggestion as to cause of problem(s) and appropriate repairs would be appreciated.
Also, advice on a reputable service agent in the ACT/Southern NSW area would be appreciated.
  • lochie3494 Nov 16, 2007
    Solution offered by 'expert' does not provide any detail..... "seal wore out" - which seal or seals might be worn out?; are these serviceable by me or is this a service agent job? etc. If service agent attention is required recommended can you advise of such in the ACT region?
    More definitive advice would be good - assistance requested. As advised in original request I have a Gaggia Classic (5 yrs old)
  • 111 Answers
Your best bet at this point is to run a descaler through it, my machine did a similar thing and it turned out to be an inexpensive fix. you can pick up descaler and cleaner at parts guru..
try this before going any further as it may save you a lot of cash.
hope this helps,
Posted on Nov 16, 2007
  • 306 Answers
As far as repairs, Sounds like the seal is wore out and is causing air leaks,
For repairs I need make and model of the machine to locate service, or you could enter it in on the main home page of this site.
Posted on Nov 15, 2007
I have miele CVA 4070 It just recently started only brewing about 1/2 to 2/3 cup of coffee or espresso and the rest of it goes into the waste container. So the waste container has a watery puck and...
Have you clean the brew unit with the cleaning tablets? This dissolves and rids the brew unit of the oils which in turn build up and clog the brew unit - the result being watery pucks and less product being disbursed.
Feb 21, 2014 | Miele Coffee System
I just cleaned our the brew group of my Saeco Vienna Plus and I unscrewed the screen and cleaned it also. Now when I brew, I am getting a puddle of water in my grounds bin along with the grounds puck. I...
First, I'm NOT a Saeco technician, But I have worked on similar machines. It's odd that you had to clean the screen of the machine though I'm not sure it this is a recommended procedure as these home "super automatic" are a ROBOT espresso maker. Yes on large espresso machines the group screen is easily removed for daily or at minimal weekly cleaning. There is a screw in the center which is easily removed and screen is brushed till clear of grounds.
* I'm surprised that you can access this screen. But since you have already done so then I guessing you disassembled the piston
assembly (the part that squeezes the grounds to form the puck.
* Okay, The group usually has a number of gaskets (or O-rings)
and I can see from the "Gasket Set"
There are quite a few gaskets. Now since these are available on line I'm guessing they have been made available to those willing to replace them. So maybe your okay.
* I suspect one or more of the gaskets are not sitting just right to make a proper seal. It's either broken or not in place. Thus the group leaks and water is probably leaking past the piston and leaks on puck after it dumps.
* There is another possible problem (watery pucks) is that the piston is not compressing the coffee into a proper puck. It needs to squeeze the grounds down to restrict and slow down the hot water giving it enough time to extract the coffee essence from the grounds. If your getting weak coffee and watery, loose pucks then it's the piston. This could be caused by a misplaced compression spring or that loose gasket getting in the way.
* I would normally suggest you calling for service. But Since you have already taken this unit apart (and I Don't know about the warranty) You may have to carefully work your way backwards on what you did to see if anything is missing or loose. Go all the way back to where you think was the end and look around. Put it all back together and try again.
* Okay NOW I remember this machine! It's on youtube BUT I'm cringing as I watch it! Really don't like this machine (Sorry) I had 15 come into the shop and only got 3 to work. Way too many sensors and safeties. I still got an old one in the garage that worked for a month then stopped for no reason. Okay here is the link Good luck!
Aloha, ukeboy57
Jan 14, 2018 | Saeco Vienna Plus Espresso Machine
Hi, I have a kitchenaid artisan espresso machine model 5KES100. The espresso boiler is not producing any water, just some steam or nothing at all. I have replaced the pump, but there is no water being...
I would remove the filter grille from the group head (Philips screw) and then clean the surface behind that sufficient that you can see and then unscrew the 2x Allen head bolts holding the aluminium puck in place. The puck will be frozen in place even after bolt removal but easily broken away by levering it with a large screwdriver. You can lever against the bracket that carries the group handle. Once you have the puck out scrape it clean and buff it up with a wire brush and clean out the 4 holes through the puck where the water is supposed to pass through on its way to the coffee. Check if the group seal has gone hard and replace it while the puck is out if it has. When done reassemble it. Blockage of those 4 holes is a very common cause of zero flow. It's doubtful the solenoids will be faulty but not impossible. It is possible that a solenoid coil has gone open though, testing and comparing with a meter or just swap the coffee and steam coils over will prove/disprove that one.
Jul 10, 2017 | KitchenAid Artisan
Coffe is too watery, and pucks are very loose
Try adjusting the grind finer. You have to do this while the grinder is running, Try 2 numbers towards fine. Then you will have to brew 2 coffees to get a reading on your adjustment.
Mar 02, 2011 | Saeco Incanto Classic Espresso Machine
Ascaso Dream Leaking Water
Correct, inside the grouphead their is a gasket which is the same diameter as the filterholter which make the perfect fit so the presure of the water will not leak out. So now either the gasket is damage in one point so you have the leak from that point. Second the gasket have become hard so it can not make perfect fit with filter holder. In both above case you have to replace the gasket. Finally their is aposibility that the gasket is dirty with coffee remains and again we can not have a perfect fit. You can use a hard brash with the water running so you can clean the gasket.
With this case you can unsrew also the shower from the grouphead and clean it also for better coffe results
May 05, 2010 | Ascaso Dream Espresso Machine
I'm trying to clean my gaggia classic. Got the
The central part is the group head it id held in by two hex head screws.
You will need to remove this first to change the group gasket.
Feb 09, 2010 | Gaggia Classic Espresso Machine
I removed the brew group to clean it and used the plastic key thing to undo one of the metal screens to clean it but since then coffee grounds are appearing in my espressos and the pucks are watery. I have...
am scos firele de contact de la grupul de incalzire al expresorului meu saeco model vechi si numai stiue exact care si *** vin la locul lor
aveti vreo schema sau vreo solutie saa o pot rezlva
Jan 16, 2010 | Saeco Magic De Luxe Espresso Machine
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Leaky head and quick shots
Have a look at the seal for the group handle. I have a different machine but this may of hardened and cracked. I'm sure you can get a replacement, may be hard to remove if it's gone very hard.
Mar 28, 2009 | Rancilio Silvia Espresso Machine
Gaggia Classic Group Head Stuck
try this website
Mar 06, 2009 | Gaggia Classic Espresso Machine
Gaggia Classic Brushed Stainless Steel Espresso Machine Logo
403 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Oloyede Monsuru
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
