Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
I have a flotec jet pump for a shallow well. It keeps throwing the GFI and shutting off after only 10-15 seconds. I have replaced receptacle, water level is fine (has a float).
  • stewartgm Jul 12, 2009
    I have already changed out the GFI so I know it's not that. The motor turns freely. I was suspecting the start capacitor.
  • 50 Answers
If this is a new problem that has just started
The GFI mite be bad or the motor mite be going bad Need to check the amp draw of the motor this will tell you witch is the problem
Posted on Jul 12, 2009
Need manual for ACE5S 1/2hp well pump
https://inspectapedia.com/water/Water_Ace_Pump_Manual.pdf
Add Comment if this is not the manual. Your question is posed under Flotec Corrosion Resistant Shallow Well Jet Pump, but you requested a manual for ACE51 pump.
http://www.wellpumpsystem.com/tags/ace5s/
May 05, 2018 | Flotec Corrosion Resistant Shallow Well...
Why isn't my pump pumping any water
Flotec FP4012-10 1/2 HP Shallow Well Pump Jet ...
www.amazon-associate.com/Flotec-FP4012-10...Well.../B0002YXB14?...
Find helpful customer reviews and review ratings for Flotec FP4012-10 1/2 HP ... After realizing the failure was due to a high amount of sediment in my well I ...
Aug 30, 2015 | Flotec Pump FP4022-10
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
My flotec well pump will squirt water and then stop . I keep feeding it water slowly but it won;t prime. What should I be doing?
Check for an air leak in your siphon line. It can be very small and totally prevent the pump from priming.
Jun 08, 2010 | Flotec Corrosion Resistant Shallow Well...
Why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
May 15, 2010 | Flotec Corrosion Resistant Shallow Well...
Loss of power and then no water comes out for like thirty seconds then full pressure comes back
something might be stuck inside the pump, try cleaning it out with a water hose the best you can.
Jan 23, 2010 | Flotec Corrosion Resistant Shallow Well...
Pump stopped working while pumping
Yes, most motors are thermally protected. It is usually bi-metallic, and resets itself.
--W/D--
Aug 08, 2009 | Flotec Corrosion Resistant Shallow Well...
I have a Flotec FP 4022-10 3/4 hp shallow well pump. It was working fine yesterday afternoon and then in the evening I had no water. I replaced the pressure switch and checked the pressure in the tank...
If heating up, the motor thermal switch is opening to shut down the motor; this is by design. During the brief run time does it pump at all? It sounds as if there may be mechanical issues on the pump itself and the motor (from the extra draw) is heating up and shutting down. I'd look in to the pump to see if anything had failed within it.
I hope this may have helped,
Tom
Jul 16, 2009 | Flotec Corrosion Resistant Shallow Well...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
233 people viewed this question
Top Flotec Plumbing Experts
john h
Andrew Bugbee
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
