Question about Saeco D-XXDX 8-Cup Coffee Maker
12+3+5+5+5+5+5+5+4+4+1+74+74+4+1+4+46+6+5 addition
  • 132 Answers
Say it 12345678900000000000
any problem
thank you for rest time
Posted on Jul 11, 2009
Hi , can you tell me what is the torque settings for Main,biggens and head bolts for Opel combo 1.4 16v 2006 model z14xep motor?
STANDARD TYPE GM ROD BOLTS
STAGE 1---18 LB/FT (GRAPHITE GREASE UNDER HEAD, OIL THREADS)
STAGE 2---30 DEG's additional bolt head rotation.
CRANK BOLT
GRAPHITE GREASE UNDER HEAD & WASHER, OIL THREAD
STAGE 1---70 LB/FT
STAGE 3---15 DEG's additional bolt head rotation.
CYLINDER HEAD BOLTS for standard gaskets
GRAPHITE GREASE UNDER HEADS & WASHERS, OIL THREADS
SEE SEPARATE SHEET FOR TIGHTNING SEQUENCE
STAGE 1---18 LB/FT 25NM
STAGE 2---90 DEG's additional bolt head rotation.
STAGE 3---90 DEG's additional bolt head rotation.
STAGE 4---90 DEG's additional bolt head rotation.
STAGE 5---45 DEG's additional bolt head rotation.
Nov 06, 2016 | Opel Cars & Trucks
I have a 55 plate Mazda 3 with a Error Code of P2584 Fuel Additive Control Module Requested MIL Illumination. Any pointers as to the possible fault?
Hi there:
This means the DPF additive needs topping up/re-filling. This additive is injected into the engine with the diesel to clean out the DPF filter (automatic system).
These fault codes appear when the additive level has dropped too low preventing the automatic injection of additive.
The cure is to have the additive re-filled, and the DPF 'primed' using Mazda diagnostic equipment.
Check HERE additional details.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 25, 2012 | Mazda Cars & Trucks
Utorrent is not responding.
have you tried to reinstall utorrent? if so, and it still doesn't work, you can remove utorrent and then run ccleaner which you can download from piriform.com after running it, try and do the installation again. if still no help i'd try a different torrent program such as vuze.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 09, 2012 | Computers & Internet
Problem Event Name: AppHangB1 Application Name: YahooMessenger.exe Application Version: 9.0.0.2152 Application Timestamp: 49c1a403 Hang Signature: 441b Hang Type: 1 OS...
Just uninstall it through control panel then install the latest version and you shouldn't have a problem. Cheers from Scott and plz vote
Jan 13, 2011 | Computers & Internet
Hi there, I am using a compaq 615 with Vista and am having trouble using the web cam. So I downloaded the software from :...
I think you will be better advised to uninstall the current software and download the latest webcam software from the HP support website
Dec 14, 2009 | HP Computers & Internet
Sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe ...
sst programing on saitek X52pro , ones install I clik on the place that Im suppost to setup , then got messge error : Problem signature: Problem Event Name: APPCRASH Application Name: ProfileU.exe Application Version: 4.3.4.17 Application Timestamp: 44fd31e8 Fault Module Name: ProfileU.exe Fault Module Version: 4.3.4.17 Fault Module Timestamp: 44fd31e8 Exception Code: c0000005 Exception Offset: 00001fda OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 253c Additional Information 2: 287b034b0bef0590cba0ccef4c4b4b77 Additional Information 3: 7de0 Additional Information 4: bfe79fb32a74e3eb99cc45f1169d5e8b
Aug 07, 2009 | Computers & Internet
Arcsoft VideoImpression
This is windows Vista? What have you changed since it started crashing? The most common cause of crashing programs like this are the result of a graphics driver.
Mar 07, 2017 | Arcsoft VideoImpression 2 for PC
Saeco D-XXDX 8-Cup Coffee Maker Logo
48 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
eyecam
Marvin
Marvin
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
