I have a model #hln5065w 50'' DLP TV. How do I know if the cooling fan is bad vs. the color wheel? Are the symptoms the same?
  • 304 Answers
No the symptoms are not the same. If you hear a lou whine or buzzing or see the color fluctuating or no color then it is the Color Wheel. If any one of the three fans are bad you will see a CHECK FAN# on the screen. Fans on these sets very rarely go out. The Color Wheels will fail before a fan will. Color Wheel part# is BP96-00250A.
Posted on Jul 16, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Power come on the tv no pix lamp light comes on then blinks then all three lights flash
Ballast is possible and so is color wheel if bad or one of the two plugs from it is in wrong---ribbon cable on wheel can be inserted backwards and has contacts only on one side.
May 30, 2012 | Samsung HLN5065W 50" DLP TV
I have a 50 inch hLn5065w ,when i turn it on a very lous noise and vibration seem to be coming if your looking at the back of the tv its coming from the right side looking from the back.i know its not a...
Problem is the Color Wheel, Located behind the Lamp .
You will need a Flash Light and Pull Lamp out ,Look inside and you will see Color Wheel.
Color Wheel PN# BP96-00250A Price $82.66
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Feb 25, 2011 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung DLP HLN5065W tv Black & White Picture
Yes,the problem is the colors wheel it dead.That one of the cause by the colors wheel,other are alots of squiling noises and making very loud buzzing sound.The cooling fan that u think is overheating,does it stop sometimes,when the tv is still on?Yes,than replaced it also,no than it still ok.Just hire the tv repairman,the parts he'll take care of it,don't order the parts,u might get the wrong parts or different sizes,that will not fit in ur tv.
May 23, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLN5065W 50 in. Rear Projection HDTV-Ready
With the back off of the set it will shut off. There is a lever it engages to prevent the set being operated with the back off.
The color Wheel will cause a fan like or high pitched grinding noise. I can tell you where to buy it and also there are on the internet places with written and VIDEO instructions for the replacement in most of these sets.
Put the back on and see if the set again works and still has the noise.
If this helped you, rate this as I do this here for FREE.
SD TECH
Nov 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung hln5065w dlp blows bulbs
The N series, needs to be told via service menu options, what type of bulb is being installed.
Jun 23, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065 DLP TV - Turns on, have low quality picture
you have a bad color wheel replace it yourself its easy part is 95.00 plus s/h
May 26, 2009 | Samsung HLN5065W 50" Rear Projection...
Noise from Samsung rear projection DLP HD TV.
this noise is an indication of a bad color wheel. aa dlp uses a mechanical motor to spin a coloered segment disk. this turn the white light of the lamp into your colors of pictures. Now anything that moves will eventally break. the flickering is also an indication of a color wheel going bad. eventally this will cause the set to shut down. Color wheels can be replaced. i dont know your model so i am not sure of the exact replacement procedure. at my shop we charge average 250 for such a repair
Oct 31, 2008 | Samsung HLN5065W 50" Rear Projection...
Noise from tv
I had the same problem with a 5065. I purchased and installed a new color wheel and that solved the noise problem. The color wheel has a bearing that gets "dry", and when it fails it does sound like a fan bearing.
Jul 10, 2008 | Samsung HLN5065W 50" Rear Projection...
Televison & Video Logo
87 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
