Question about Cuisinart DGB-500 Coffee Maker
It won't stop beeping. I've unplugged it for hours to reset the clock, but it still keep beeping. I've cleaning it, I've smacked it. It won't stop beeping.
  • dmtdds Jul 16, 2009
    I don't use the carbon filter, and recently cleaned with vinegar. Trap at the botton of water basin is clean. I think coffee dust gets on electrical contacts and mucks up the circuits. I've gone through a couple of these units in the last 6 years, same problem.
  • 85 Answers
Hello dmtdds,
This should be an easy fix. Inside the top of most Cuisinarts there is a water filter stick. Usually in one of the corners. Pull it out and remove the clogged carbon filter. Clean out the debris in the bottom of the cavity. Replace the filter stick into the cavity. (You can buy new filters on Amazon inexpensively, they should be replaced every 60 days.) Flush your unit with 2 parts water and 1 part vinegar, then rinse with a pot of fresh water. The beeping should stop and you should be good to go.
Hope this helps you. Good luck! Positive feedback appreciated. NormanZ
Posted on Jul 15, 2009
How do you set the minutes on the clock?
There are two ways to set the clock on your coffee maker. 1- When you initially plug in the coffee maker, the unit will beep and "12:00" will flash on the LCD display for a few seconds. Press immediately the h/min button (o) to set the current hour. If "12:00" starts to flash, press the PROG button (n) for a few seconds until the "12:00" flashes again. Then press the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. 2- At any other time, you can set the clock or change the set time by pressing and holding the h/min button (o). The unit will beep and "12:00" will flash on the LCD display. Use the h/min button (o) to set the current hour. There are AM and PM indicators on the top right side of the LCD screen. To set the current minutes, press the PROG button (n) and then press the h/min button (o) until the correct minutes appear on the LCD display. After 5 seconds, the unit will beep and the time will stop flashing. Notes: Your clock has now been set and will continue to keep the correct time, even after the coffee maker has been shut off. Unplugging the coffee maker or a power failure will reset the clock to 12:00 AM. Repeat the instructions above to reset the clock
Source : Krupsusa.com
Link to manual : http://product-support.groupeseb.co.uk/Download/Pdf/366/km730
Mar 21, 2016 | Krups KM730D Breakfast Set Coffee Maker...
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
My oven just started beeping and flashing an F1 symbol and won't stop for a while. Can someone tell me why this is and how to fix it? Thank you so very much.
You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer.
Note: A hair dryer will help you get the face off the old one to put onto the new one
Please rate this solution
Rnj VINODKUMAR
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Buttons dont work on danby microwave
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it still isn;t working I would contact Danby Customer Service US / Canada.
Jan 08, 2009 | Danby DMW1146SS Microwave Oven
Frigidaire Gallery Self Cleaning Oven
F1 code on frigidaire is bad EOC (clock) Try shutting breaker off 20-30mins see if it resets itself.
Jul 12, 2008 | Kitchen Ranges
Cuisinart DGB-500 Coffee Maker Logo
1,489 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
