Question about Nintendo Wii Console
Error code 52130purchased a linksys wireless router, and my wi cant connect to internet, i entered the passphrase given and still get error code 52130
  • 341 Answers
    Genius:
  • 1,234 Answers
Error Code: 52130 There appears to be an issue with your wireless router's firewall.
  1. Make sure your router is not listed on our "known incompatible routers" page, by clicking here.
  2. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
    4. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  3. Disabling your router's wireless security may help the Wii console's online connection. Consult your wireless router's manual or check with the router manufacturer for more details. Please note Nintendo provides these recom mendations as a resource to our consumers; it is up to each consumer to determine if adjusting their router's security settings are the right choice for their home network.
  4. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
Posted on Aug 26, 2010
4 Suggested Answers
larkin71
  • 38 Answers
SOURCE: error 52030 in internet connections
one option is try choosing a different type for your password...i've had the same error before and what i did was to change the password type e.g. from wpa aes-tkip to wpa-aes passphrase (this option will appear during your wii internet connection set-up as you would probably know by now) and everything right afer started to fall in place perfectly...my wii started connecting to my router and never had the same error code ever since.
Posted on Mar 08, 2008
  • 4 Answers
SOURCE: I'm trying to connect my DSi to my home network through my router
if your computer can do the internet, the only thing i can suggest as i have limited knowledge is that you get a Nintendo LAN adapter which you plug into your computer when its online and it sends the WiFi signal to the DSi
Posted on Jun 15, 2009
Kagayaite
  • 15 Answers
SOURCE: My dsi can't connect to the internet using my
Your router is using a security method the DS cannot handle, because it does not possess the processing power of modern Laptops or Desktops it is unable to use the more sophisticated encryption and security protocols. Try changing the wireless security to WEP protection.
Posted on Aug 11, 2009
Want a secure line
kb19073-001_en.png NOTE: Image may vary depending on the type of router and computer you are using.
To setup your router's wireless security settings:
i. Accessing the web-based setup page
ii. Setting-Up the Wireless Security
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and the Username field is left blank. If you have set a password before but forgot it, you need to reset the device. For instructions on how to reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26 hexadecimal digits. This encryption will prevent other users from connecting to your wireless network. It will also protect your wireless transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher level of encryption compared to the 64 bit WEP. It uses a 104 bit (26 Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click kb19073-007_en.png.
Wi-Fi Protected Access (WPA)
Wi-Fi Protected Access (WPA) is a Wi-Fi standard designed to improve the security features of WEP. WPA is stronger than WEP encryption. PSK and PSK2, the two types of WPA, give you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in the list of choices for the Security Mode then you might need to upgrade the firmware of your router to its latest version. Upgrading the firmware can fix the bugs of the previous version and update its other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click kb19073-011_en.png.
Sep 19, 2011 | Linksys Wireless-G WRT54G Router
How can i lock my router
1. Use an ethernet cable to connect a computer to any one of the four LAN ports of the linksys router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password , unless you have already changed it.
4. Select Wireless Settings from the Setup menu in the left-hand navigation bar.
Under SSID Name, Give a Unique name for Wireless N/w
5. Under Security Options, select WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
6. Under Security Encryption (WPA-PSK) > Passphrase, enter a passphrase.
7. * The passphrase may either be a string of 64 hexidecimal digits, or word/phrase of 8-63 ASCII characters.
* SAVE or KEEP NOTE of the passphrase - it will be required to connect wirelessly to your network.
8. Click Apply to save your settings.
9. Scan and Connect to your Wireless N/w on your Wireless Computer with your Password
Oct 02, 2010 | Linksys WRT300N Wireless Router
I want to have a passphrase but no key numbers, how do I do this?
Open a browser and enter the Linksys configuration URL, enter the login and password and then go to the wireless settings to configure the encryption setting. I suggest you use WPA or WPA2 encryption, this is the latest and strongest encryption method. You can enter the passphrase instead of hex numbers. Use this passphrase to configure the wireless card in your computer/laptop so it can connect to the Linksys wireless router.
Sep 20, 2010 | Linksys Wireless-G WRT54GS Router...
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Cant find wep key
Your printer is saying that you should secure your wireless internet. Try resetting the router by holding the reset button located on the back for at least 30 seconds.
Nov 20, 2009 | Linksys WRT160N Wireless Router
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
When connecting to a wirlies singnel
If the wireless security on your router is set to WEP, you should use the long key that was generated from the passphrase for your wireless computer so it will connect fine and work to the internet...
Dec 31, 2008 | Linksys Wireless-G WRT54GS Router...
Protection on my Mac
Given that you have setup the Internet connection on your router, encrypting the wireless security will be fairly easy for you. Just follow these steps.
1. You should use you PC or MAC that is connected directly to the router via an ethernet cable. You can use PC or MAC, which ever is connected directly to the router (Connected thru cable not wireless).
2. Open Internet Explorer / Firefox (PC) or Safari / Firefox / Internet Explorer (MAC), then go to the address bar and type http://192.168.1.1 into the address bar and press enter. A window will pop up prompting you for a username and password to access the configuration page for your router. Leave the username blank and type admin as the password (**If that will not work, (Enter admin for both the username and password)
3. You should see the Setup page shown below :
4. Click on the Wireless tab at the top of the settings screen. Change the Wireless Network Name (SSID) from the default value to something unique (you can use your name or last name, or any name that you would like, because that will be the name of your wireless network, that will be the one that your wireless computers will detect) then click on Save Settings and then Continue when the Settings are successful dialog is displayed.
5. Now click on the Wireless Security subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 64 bits 10 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. It Will generate 4 keys (Key 1-4). You will use key 1 as your password.
6. Finally click Save Settings and then Continue when the Settings are successful dialog is displayed.
7. Now let your wireless PC scan for available wireless networks, find the name of the wireless network that you have specified earlier for SSID then connect to that network. Of course since the network is password protected, it will ask you to enter a password, this is time that you will enter the network key (Key 1 - password).
Oct 29, 2008 | Linksys Wireless-G Broadband Router
WUSB54GC model wireless adapter won't connect after months of use
Instead of using the passphrase use the wep key 1 that you created on the router page when you generate it using the passphrase.
Then when you try to connect using the linksys wireless monitor just leave the passphrase blank and type in the wep key1 box the key that I mentioned earlier.
May 17, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Nintendo Wii Console Logo
841 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
juanmireles1
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
