Question about Gaggia Classic Espresso Machine
How do you remove the the shower holder plate. Frozen in place and don't want to damage allen bolt holes trying to pry loose.
    Scholar:
  • 36 Answers
Hi there, once you remove the screw if you get a fine headed screwdriver and prise it off from the centre hole where you took the screw from. Don't be shy the block underneath is very solid. It will come away and show you the two hex nuts. Remove the two hex nuts with an allen key to fit and then again prise with screwdriver in one of the holes until it pops off. I fix these machines every day and some can be very hard to get off. Don't be shy with giving it a bit of oomff to get it off. All the group head parts are very solid metals and are dificult to dammage. That should hopefully help you out and if you have any further problems please get in touch with David at coffeeservice@live.com and he can help you out.
All the best
LaPavoniBoy
Posted on Jul 14, 2009
There are two shower handles, one to divert to the shower head and another to divert to the rain head. one of these handles has loosened and falls away from the neck.
Look for an Allen screw hole the Allen is loose or has stripped and needs to be changed out. Sometimes if they are over righted they strip on bottom, also make sure it hasn't backed out completely. Some older handled have a square piece that the handle goes over then the screw is tightened under a plastic cap tha has hot H or cold C on cover.
Aug 29, 2015 | Grohe Home
Shower holding plate stuck
If the shower holder is stuck, it it probably stuck with lime or coffee oils. You could try backflushing with a little descaler if the gasket is still in place. That will dislodge some of the lime and then can be pried off with a flat screw driver. In case you damage/ break it - you can get one here. Gaggia classic portafilter
Apr 25, 2015 | Gaggia Classic Espresso Machine
I have a 1997 ford explorer. Im trying to discover
Im just guessing here, but some cup holder have a rubber piece in the bottom, There may be screws under these, if not most consoles have a center cover that can be pried up and removed and there should be screws under that cover. Pry carefully as you could damage the cover. If it don't come with light prying chances are it is not made to come off. Some times the arm rest has to be remove to get to screws that hold these covers on.
I hope this helps you get to what you want. I wish you luck.
Oct 15, 2014 | 1997 Ford Explorer AWD
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
Grohe shower bracket loose
Had the same issue, my suggestion is: 1) find out what model it is 2) go to the Grohe site and go to the tech specs of the glider element 3) for my unit you need to insert a 3" Allen key into the hole in the center of the holder unit and tighten.. worked for me http://cdn08.grohe.com/lib/1/tpi/766909.pdf
Jun 30, 2012 | Grohe Home
How do i get the fly wheel off of my 5hp techumseh engine without breaking it
Hi and welcome to FixYa. I am Kelly
There are 3 ways to get it off.
1. Use the flywheel remover tool from tecumseh that threads onto the crankshaft threads. Tiy then strike that tool with a hammer to loosen the flywheel on the tapered shaft while applying a prying force under the flywheel.
2. Back the nut off on the crankshaft until the nut face is just flush with the bitter end of the crankshaft. The use a VERY large screwdriver or mini-crowbar under the flywheel to apply prying force. I find it is best if you use both a very large screw driver and a mini-crowbar while a 2nd person strikes the NUT flat / straight down on the end of the crank shaft. It will pop free and probably scare you when it comes loose. After it comes loose remove the nut and the flywheel.
NOTE: Many of these engines have an OFFSET flywheel key if the engine has electronic ignition. If your not sure about the integrity of the flywheel key replace it. They are cheap.
3. If the flywheel has 2 threaded holes in it... you can make a flat puller plate with 2 holes that will cover the end of the crankshaft and the 2 holes you drill in the plate match up with the holes in the flywheel. You then use long bolts to screw into the 2 holes of the flywheel and the flat plate acts as a puller. You tension the bolts and strike the plate to get it to come free.
I have done all 3 of the above repeatedly. Just be careful when prying on the block so that you do NOT punch a hole in the case. Pry on the ribbed area of the block if possible. If not put a metal plate or thin block of wood against the case so as not to damage it.
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Garden
I am trying to remove the shower valve handle off a 20 year old unit. It has a chrome plated brass handle. When I removed the plastic cap off the front there was no screws attaching it to the valve. There...
Hi Denny--
It's a good idea to valve off the water to the fixture in question before you begin, as you can get wet doing this.
Inside that small hole you found should be an allen screw--of what size I am unsure. A standard-sized allen pack should have the size necessary.
Experiment by selecting the smallest available size, inserting it into the hole, and then trying to unscrew. If you don't feel anything catch, try the next size up.
Once loosened, the allen screw should come all the way out--be careful not to drop it down the drain!
With the screw removed, you should be able to remove the handle by pulling the handle gently away from the wall. Rocking the handle perpincularly can help, too.
If the handle has been on for a great while, more muscle may be necessary. Sometimes I sneak a flatblade screwdriver--wrapped in a cotton rag--between the handle and the wall plate and, with gentle pressure, pry the handle enough to loosen the bond between handle and control stem. Be patient!
Hope this helps,
Joe.
Jan 30, 2011 | American Standard One Handle Shower Only...
Cannot remove shower holding plate
After removing the 2 allen wrench bolts in the holding plate, place the flathead screwdriver on the plate and using side of group as leverage lift. Check diagram below92b399a.jpg
May 27, 2009 | Gaggia Carezza Espresso Machine
Replace front license plate holder
On my 92 ford pu, the plastic tabs snap into square holes in the bumper. They can be snapped out when there is no bolt in the hole by using a flat screwdriver & a little prying.
Apr 11, 2009 | 1997 Ford Expedition
Do not know how to remove Shower Holding Plate
i think this will give you better picture what to do, but you dont need to remove the seal if it isnt leaking.
http://www.bluebox.com.au/jcrayon/gaggia/
Apr 01, 2009 | Coffee Makers & Espresso Machines
Gaggia Classic Espresso Machine Logo
286 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
