Question about Dometic Rooftop RV Air Conditioner
Duo Therm RV Air Condiioner-Compressor comes on before fan motor
Sometimes the compressor comes on before the fan and then shuts system off and other times the air conditioner motor does not come on at all. This is sporagic. Have tried wd 40 on the motor shaft, both coils have been cleaned and blown out recently. Inside thermostat has been factory reset. What is the problem?
  • Dometic Master
  • 6,674 Answers
I'd have someone who's familiar with capacitors, (for safety sake), to test your fan run capacitor, and power to it. If capacitor is shot, fan won't start. Have to remove cover on upper unit, then cover on side at front where wiring is, to access it.
Posted on Jul 12, 2009
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Duo-Therm ac when the temerture is reached the fan will shut off but the compressor stays running
Sounds like you hit it on the head--compressor should turn off when unit reaches the preset temperature.
Jun 10, 2012 | Dometic Rooftop RV Air Conditioner
Duo-Therm BRISKAIR on rooftop of houseboat runs, not putting out cold air. Also, fan doesn't seem to be running at top speed
Sometimes a weak capacitor will make a motor run slower so I would check that first. Also make sure the compressor is running. Let me know what you find. You may need to get the refrigerant charge checked too. By the way it may use the same capacitor for the fan and compressor.
May 26, 2010 | Dometic Rooftop RV Air Conditioner
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
Compressor intermittent
Sounds like a bad thermostat. Make sure you turn off all related breakers and disconnect switches before attempting to replace it. Good Luck!
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Jun 01, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
206 people viewed this question
Top Dometic Heating & Cooling Experts
Donni Steen
Jay Finke
Jay Finke
John Tripp
John Tripp
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
