Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Repalce cord on gas blower
I replaced the cord on a poulon 25cc gas blower but when i reassembled it, the cord jams. without the motor it is a smooth pull. is there a technique for mating the motor to the cord wheel?
    Scholar:
  • 103 Answers
MAKE SURE YOU HAVE THE RIGHT SIZE CHORD FOR THAT STYLE,MUCH SMALLER THAN MOWER STYLE. ALSO PROBABLY HAVE IMPROPER TRACKING OF ROPE. TRY PULLING COVER BACK OFF AND MAYBE KNOT GETTING CAUGHT UP IN FLYWHEEL FROM ROPE
Posted on Jul 12, 2009
My blower stops running and cord got stuck
Does it seem to be the cord holding the unit? Try to turn the blower in reverse. Disconnect the spark plug and use a screw driver to reverse the blower., If the starter pawls engaged for some reason and jammed the engine, this should free them. If not, there could be problems inside the engine.
Mar 10, 2015 | Poulan Pro 25cc 2-Cycle Gas Blower...
Carburator dirty and fouled with old gas
I would dump the old gas and put new gas in and see if it will start then. If not you can remove the carb and if you are careful disassemble it without damaging the gaskets spray it with carb cleaner and reassemble it and put it back on. You can also rebuild the carb if the second option doesn't work. Hope this helps.
Apr 22, 2014 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Fuel lines have deteriorated and need to replace
I just took mine to a local Poulon Repair shop about 16 miles away and they replaced the lines and the grommet and only charged $6. You can find someone in your area through the Poulon website:
http://www.poulan.com/service-locator/
Aug 23, 2013 | Poulan 25cc 2-Cycle Gas Powered String...
Poulon pro bvm210vs will not start
This is back to basics, does it have a good spark when the engine is rotated with the plug out? if no replace the plug and try again if yes, does the plug get wet with fuel?if no replace the filter in the tank and try again, if yes is the plug soaked with fuel? if yes check the fuel inlet needle in the carb which maybe causing flooding, if no, is the spark occuring in the correct place, to check this remove the flywheel and check the key has not sheared, if the key is ok, it may be an air leak through a gasket or crank seal.
Aug 30, 2012 | Poulan Pro 25cc 2-Cycle Gas Blower...
My poulon pro leaf blower will start then stop. I have installed a new fuel line but still having the same problem.
Check and see if the carburator mounting bolts have come loose creating a vaccume leak. on small engines this is common due to vibration while operating.
Jun 04, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
Need to attach starter pull cord on a poulon leaf blower BVM200VS
I had the same problem. I opened up the blower by removing all the Allen screws, 4 mm wrench.
Then pull the motor, need a Torx T-25wrench. You then need to wind up the recoil which is part of the case on the motor side. Wind it up all the way and then put a screw in the slot that is in the recoil.
Thread the cord through the tube through the triangular hole in the white disc. Type a big not that won't slip through the hole. Pull the screw that is holding against the spring.
Remount the motor, wiggling it until it slips into place. Make sure it ratchets.
Reassemble and you shold be good to go. Only took me 3 attempts to get it right.
Oct 01, 2010 | Poulan Garden
Need to thread the cord on a poulon 031pro
Remove the side coverto get to reel Remove any broken cord. Turn reecounter clockwise till it nestops then slowly let turn back till the hole li nes up then use a c clamp to hold the reel. Feed the cord through hole about 3 to 4 inches and tie a double knot in cord. Release c clamp very slowly to take up cord. Measure old cord if possible and subtract about 1 half inch cut it and thread it through the handle. replace the side cover.
Apr 30, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Weed eater Feather Lite Blower - replacing pull cord -can't figure out how to get to it
This should help you out. Go to Poulon's website. Look for a tab to "order parts". Model is fl1500. That will take you to a page that you can look at the blower "chassis" to order parts. That shows you how the bottom housing goes together. You have to take off the bottom housing, the blower fan, the top housing. That should take you to the starter cord mechanism.
Good luck.
http://www.ordertree.com/ARI.aspx?Mfg=75&Model=FL1500 Gas Blower Type 3&AFID=59
Nov 21, 2009 | Garden
Craftsman 17" 25cc Trimmer...pull cord stuck
it's doubtful that bad gas caused this, it sounds like the cord was back-lashed and partially came off the recoil pulley. Remove the recoil cover and ensure the cord is all on the pulley, make sure the rewind mechanism works smoothly before re-installing.
May 07, 2009 | Craftsman 25cc Gas Line Trimmer
Problem with air blower...
BlowerMotor Relay is Located On Driver Side in Engine Compartment and is the LARGE Relay in center of box CLOSEST to you If you are Standing On the Driver side of Car This is A Culpret, Also the "BLOWER MOTOR RESISTOR" also can Cause What You describe.
I HAVE PICTERS AND Manual Info But need Email Address to send as FixYa Wont Exept this Type of Files
Blower Unit Components Replacement
Note these items when overhauling the blower unit:
The recirculation control motor, the power transistor ), the blower motor (C), and the dust and pollen filters (D) can be replaced without removing the blower unit.
  • Before reassembly, make sure that the recirculation control linkage and doors move smoothly.
  • After reassembly, make sure the recirculation control motor runs smoothly.
Feb 12, 2009 | 2003 Acura RSX
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
367 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
roeb
Jay Finke
Jay Finke
Are you a Poulan Garden Expert? Answer questions, earn points and help others
