You did not include a model number so this is very generic. When an ice maker slows or stops production often the problem is not the ice maker but a symptom of other problems. The biggest reason they stop working and you still have water in door is that here is an ice block on the evaporator coils. The freezer has to cool down to 14 - 16 F before the ice maker thermostat will actuate and begine the harvest cycle.
There are other reasons they stop working
1. The inlet water valve solenoid has failed
2. The inlet water valve is clogged with debris only on the ice maker supply side.
3. The ice maker thermostat fails
4. The ice maker fill fill tube is frozen closed (
5. The ice maker module or (optics depending upon model) has failed
6. The evaporator fan is turning to slow or not working.
If you would respond with a model number I may be able to send you links to a manual or 2 that would help you troubleshoot.
Now... back to the beginning.. IF you note ice build up / lots of frost in the back of the freezer do the following:
1. Unplug the unit and remove freezer contents
2. Direct a fan into the freezer compartment for just about 2 hours. (water mess)
3. While the unit is defrosting open the lower back of the unit (Compressor area) and clean the condenser coils and fan. Make sure to also clean the drip pan and the END of the compartment drain tube.
4. Clean up the water mess and return the unit to normal service.
If it starts making ice in 6 - 8 hours you have an automatic defrost system problem. Possible causes for NOT defrosting automatically:
1. Defrost control or timer failure (depending on model)
2. Defrost heating element failure
3. Defrost thermostat or thermistor failure depending upon model.
4. Wiring.
Everything should be fine for at least 2 days. If there is an automatic defrosting problem, the ice production will slow and then stop as more ice builds up on the evaporator coils.
I had a similiar problem. The unit would only flash deficient. I removed the rear cover (3 screws along the back top, 3 screws underneath, and the 2 feet), then opened the panel to access the control board and disconnected the temp. sensor. Working great now, but the deficient continues to flash. Hopefully i will be able to find a replacement part.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Here is a tip that I wrote about the reasons why ice makers do not work.
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else
remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
