It depends. If if has an external power supply, you can try a different supply of the same rating. Beyond that, it may be a blown fuse, which may be internal on the power supply board, or as you say perhaps a broken power switch. Whether it's easy or not will depend on your diagnostic skills, how much you know about electronic repairs, and your availability of parts.
Generally, i suggest people take their repairs to professionals as poking around inside electronic gear can cause more damage, both to the gear and to themselves.
Hi :). Are you referring in Casio Cleviano model AP-33? Because i try to search for Casio Cleviano but there is no result. the only available is the model for Casio Cleviano model AP-33. Casio AZ 1 Service Manual Parts List Page 6 . I hope this link can help you to find out the manual for your casio model. thanks
If one of the channels on your Allen & Heath XONE:42 mixer is not functioning properly, it is likely due to a problem with the channel's internal components or electronics. To repair a blown left channel, you will need to disassemble the mixer and locate the source of the problem.
Here are the general steps you can follow to troubleshoot and repair a blown channel on your Allen & Heath XONE:42 mixer:
Disconnect the mixer from any power sources and remove any cables or accessories that are connected to it.
Carefully disassemble the mixer, following the instructions in the user manual or a service manual if available.
Once you have access to the internal components of the mixer, carefully inspect the left channel for any visible damage or problems.
If you find any damaged or faulty components, you will need to replace them. You may be able to find replacement parts online or through a specialist DJ equipment retailer.
If you are not comfortable with disassembling and repairing the mixer yourself, you may want to consider taking it to a professional repair service. A technician will be able to diagnose the problem and repair the mixer for you.
Keep in mind that repairing electronic equipment can be complex and requires specialized knowledge and tools. If you are not familiar with electronics repair, it is recommended to seek the assistance of a professional.
You will probably have to go to Line 6 to get a schematic... HOWEVER, it is likely a visual inspection will reveal the failure due to dropping. Look first for bad solder at the headphone jack. Next under a bright light look for circuit board cracks. This is going to be surface mounted parts and unless you have an equiped shop, it is not likely you can successfully work on the board if it is not a visible problem.
Scroll down the site page to "Get Manual" and click on it to download.
Be careful of the ribbon cables within the unit. God to have extra hands available when opening the unit.
When he bulb blew out, it temporarily shorted and blew out the Triac that controls the voltage to the lamp. It will need to be replaced... A lot of the Chauvet units use a 16 amp, 600 volt Triac part number :
BTA16-600BRG
which is available from Digikey. It will be mounted on a heatsink.
Your best bet is to request a service manual from Peavey itself. These are usually available for around $20 or so. Call Peavey and ask for the service parts department and make your request there. They are very helpful and should be able to assist you.
