Question about Mitsubishi MSH12TN Air Conditioner
Ductless heat pump systems
I am looking at puting a ductless heat pump system im my home and i dont know how relilable these systems. i was told that they dont work very will in temperatures around zero degrees. im currently looking at a Mr. Slim or Sanyo system.
  • 1,420 Answers
Fixr is correct. I do not recommend using the Mitsubishi or Sanyo below 17 degrees. It may cost you a fortune in electricity below 50 degrees depending upon where you live. Mitsubishi is the better model.
Posted on Nov 19, 2007
  • 49 Answers
Heat pumps do loose their heating capacity and efficiency as temps drop. If you decide to rely on a heat pump you may want to make sure that your system has a back up heat strip, maybe even controled with an outdoor thermostat, if that is an option. The Mitsubishi is a great product.
Posted on Nov 17, 2007
What are some examples of home automation?
HVAC, centralized control of lighting, automatic security systems, applicances, etc
Jan 30, 2013 | Home Automation
Friedrich ductless heat pump will not start up.
Did you check to see if the compressor is running? Check out start relay/capacitor.
Sep 21, 2017 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Where can I get a remote for a Model ASORD18DA Ductless and a service manual.
Hi; Look in the Yellow Pages for Your local ac supply house they can order it for You or point You to the manufacture for assistense...alpharome416
Feb 18, 2010 | GE Quiet-Aire Ductless Heat Pump Split...
Ductless heat pump - how many and where located in home
i live in sandwich and am mitsubishi expert
please call
yellowdog services
to much to type here
Sep 26, 2009 | GE Quiet-Aire Ductless Heat Pump Split...
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
My GE ductless system is not heating properly and trips breaker
Call them yourself. Let them know your compressor is tripping your breakers. Also, ask how to obtain parts for your system. It's rediculous an hvac tech cannot get advise from ge.
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
448 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
