Question about Toro Lawn Mower With Toro Power Tools
Lawn mower is stopping every time. Appears to be a problem with the gas. Even if it has gas, and I choke it, still is stopping.
    Problem Solver:
  • 7 Answers
If its a newer lawnmower losten the cap cause the fuel is gravity fed into the carb on the newer motors and also if it drain the fuel bowl as there might be contaminates in it if those fail take the carb apart and spray every hole with carb cleaner then reassamble
Posted on Jul 13, 2009
As far as I know there is no primer or choke on the 675 lawn mower engine. How do you start motor without pulling plug and shooting gas in spark plug hole?
Some mowers have a type of auto choke on them. Some Briggs and Stratton choke themselves when the engine speed is slow, and un-choke when the engine reaches full rpm.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jun 29, 2016 | Garden
My cub cadet stops running 5-10 minuts
check the bowl for dirt or try putting in some stable
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Lawn mower stays running on jumper cables but once disconnected it shuts down when choke is engaged
if it is already running and you "engage" the choke, you will flood the engine with too much gas and it will sputter and die. the only time you engage the choke is to start the engine when it is cold. if the mower dies when you remove jumper cables, and you leave the choke alone, you need to have someone look at your charging system.
Apr 08, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Runs with choke out.. dies if pushed in. Will only run a short time then seems to flood. After that it will continue to leak fuel from under the air filter somewhere until the tank is empty... crazy....
Try rebuilding the carb. It might be your float is messed up. You can also get some carb and choke cleaner and take the sediment bowl of and clean everything in it. Give extra attention to the float and needle valve. They might have some build up that won't let it work properly.
Also your gas cap might not be venting properly.
Oct 09, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower not running at set speed, choking
you should have an air/fuel mixture screw on the carb somewhere. Start the engine and turn it one way then the other a small amount at a time. One way it will get worse and one way it will get better. Keep turning till it smooths out
May 09, 2009 | Garden
Yard machine 139cc will only run short time with choke
Check the float and the adjustment screw on the bottom of the carb. Usually if the float stays up it will continue to leak gas and also will only run on choke. Spray some carb cleaner in there and try to get rid of any debri also try changing your air filter or cleaning it
Feb 08, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Toro Lawn Mower With Toro Power Tools Logo
151 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
