Question about RCA TruFlat 27F520T 27" TV
Just picked up this free tv. RCA TruFlat...it's changing channels
It's changing channels and not responding to buttons or remotes. Any ideas as to how to fic. Somebody said something about a reset button. Where is that located?
Thanks --dana
    President:
  • 3,113 Answers
The micro buttons on the tv are causing the problem. Mine kept going up in the channels like you are holding the button down. I took the button board and clipped to prongs on the micro switch to the channel up button. It has three prongs on one side and two on the other that you clip.I use the remote all the time any way and it will not affect that. You need to figure out which one it is by watching the channel direction up or down. Careful of HIGH voltage in back of TV even unplugged.
Posted on Jun 20, 2010
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
TV is on but the standby light is off and the buttons on the remote or the set will respond. Any ideas?
If it's a plasma try resetting. There should be a reset button either on the remote or on back of t.v
If not and if you cant acess your tv settings to reset. You can call Sears 24hr helpline and they will connect you to a tech. Who will help you..No it doesnt cost anything. Or get on web and look up a manual for your tv or just type in what its doing and you will possibly find your answer, but I think it just needs resetting and updated.
Dec 18, 2014 | LG 47LG50 47 in. LCD HDTV
Tv says receiver is not on and do not respond to remote control
Hi Jackiewes928, I apologize for the inconvenience you have experienced. It is my pleasure to assist you today. I understand that the only channel you are currently getting is channel 116 and that your remote is not responding. Do any buttons at the top light up on the remote when you try to change channels? If so, what button lights up in red or green? if any button other the SAT button lights up this means that the remote is not on SAT mode and this would be why is not responding. In order to put the remote in SAT mode press the SAT button for 3 seconds. Once you do this try using the remote. If you need further assistance please feel free to reach me directly at kimberly.escobar@dish.com
Feb 06, 2013 | DISH Network IR Remote Control
Can't change channel using the remote or buttons on tv
Simple Fix
I had the same problem, couldn't change the channels with the remote or on the side of the TV. This was for a Vizio 37"
Here is the fix:
1. Turn on TV
2. With remote, press the Menu Button
3. Go to Antenna Menu
4. Select Auto Search
Let it search, it could take several minutes. It may not finish to 100%, mine got stuck at 79% for 10 minutes. It's fine if that happens, go ahead and cancel.
5. It should be done, your remote will work perfect along with the TV channel buttons.
Sep 07, 2008 | Vizio L32 32 in. LCD HDTV
Tv is on but wont play
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Give the brand name and the model number..
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Televison & Video
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
RCA TruFlat  27F520T 27" TV Logo
97 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
