Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Black spots on ice
I have a whirlpool gold side by side fridge. I am getting black spots on some of my ice cubes. I don't think my ice molds are black, they appear ( the parts that I can see at least ) to be white. Also, the water hose that runs from the wall to the fridge is white. What should I do?
  • Kenmore Master
  • 3,361 Answers
The ice maker mold is deteriorating. Replace the ice maker.
Posted on Jul 11, 2009
Black spots in ice for brand new installation
Crazy...
I would pat myself on the back a couple more days... and let the whole fringe get better (settle & wash out).
Just an errant thought...but if you have a water filter on your water supply I'm thinking I would rather know WHAT those spots were...
I'm thinking CHARCOAL (meaningless/harmless).
No FILTER = IRON OXIDE...
Means you have an advanced case of copper directly connected to steel pipe causing ELECTROLYSIS...
Find it fast or make sure your insurance is up to snuff.
I would capture a sample and test with a magnet
Some manufacturers suggest you toss the first load of cubes and go for it...
I think you are smart to watch what you ingest.
Carnac the Magnificent
Apr 20, 2017 | KitchenAid Architect II Series KBRS19KT...
Ice machine not working
PLEASE TRY TO CLEAN THE FILTER FROM THE SUPPLY LINE WHICH COULD BE BLOCKED. BUT FIRST TRY AND LOAD A ICE CUBE WITH WATER TO SEE IF IT MAKES THE ICE IF NOT YOU FRIDGE IS NOT WORKING PROPERLY
Aug 27, 2012 | Whirlpool White Gold 25 cu. ft. ENERGY...
I replace the filter and now it dose'nt make ice
Check for a jammed ice cube in the fingers. Use a hair dryer to release the jammed cube.
Add some water to the ice mold and see if that don't speed up the process if the ice mold is empty.
After changing that filter:
Ice in the mold none in the bucket= ice maker problem
Empty mold= water supply problem
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Not making ice cubes
Fill ice maker with tap water and let freeze. If ice dumps and water does not refill tray then the water control valve is defective. If ice remains in ice maker then ice maker is the problem.
I think Amana still uses the Whirlpool made ice maker. It consits of a mold, a paddel to remove the ice, a motor to drive the paddel and a cam. The electrical part consists of mold, thermostate or sensor ( use to be thermo-disc), micro switches, 1 to hold the unit running 2nd to alow water to flow at a certain time and a mold heater. Sequence of operation: Thermostate senses mold is cold, activates motor to turn paddels and cam. As cam turns it depresses a micro switch to hold motor running. Motor cam and paddel turn, mold heater is also turned on. As mold warms the paddels scoup out the ice. Contunes to turn until a spot on the cam activates another micro switch to allow water in. Motor continues, as cam reaches a spot it releases the micro switch for water andthen the switch holding the motor on and unit shuts off ready to do it again.
Sep 09, 2010 | Amana ARB2257C Bottom Freezer Refrigerator
Ice cubes sticking in tray before dumping. Can't get it out. Lost manual Need to get it out and clean off the mineral deposits.
you may have a bad mold heater . this causes the release of the ice cubes / but do clean out the deposits . as they also prevent a proper harvest .. after cleaning spray mold with a food grade silicone .
Jul 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Conquest Defrosting
Contact the dealer/Store you got it from, it should be under warranty. Without being flippant, make sure it hasn't been turned off by mistake at the wall.
Oct 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool refrigerator icemaker does not dispense ice cubes
I don't think the ice maker liked the water being turned off. Usually there is an arm that will raise up to a catch position that will turn the ice maker off. I hate to say it, but ice makers are best to replace than repair. The internal parts are difficult to change, and with a new one you will have no problems. They are not too hard to change. Shop around for a good deal, I use e-bay.
Apr 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Our fridge does not make ice - Whirlpool Gold side-by-side GS5SHAXNT00
Same as others. Whirlpool Gold side-by-side. Water was running yesterday but minimal ice. Now that's gone and I don't even hear the water. Turned on/off the infrared sensor. Still get drinking water, just no ice in the bin. There's a couple cubes in the maker itself when I open the door (which I've closed completely). Help?
Dec 02, 2007 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
642 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
