Question about Mitsubishi WD-73735 Television
Mitsubishi wd-65732. Just today picture is significantly less bright. ''Lamp'' light on front of tv is not on. Does this sound like lamp is about to go out, or something else? TV about 3 yrs old
SOURCE: Mitsubishi Projection TV WD-62525
I RECENTLY HAD A LAMP ISSUE THAT MAY ASSIST. I HAVE A MITSUBISHI WD-52525 52" DLP. I HAVE OWNED THE UNIT JUST OVE THREE YEARS. THE UNIT INDICATED THAT THE LAMP NEEDED TO BE REPLACED WHEN THE UNIT WAS TURNED ON. I ORDERED A LAMP AND BEFORE IT CAME IN THE UNIT QUIT WORKING. I REPLACED THE LAMP AND WHEN I POWERED UP THE UNIT I GOT A STEADY YELLOW INDICATION AND THEN A SOLID RED. MITSUBISHI TECH ADVICE STATED THAT I MAY HAVE BEEN SHIPPED A BAD REPLACEMENT LAMP. I SENT THE LAMP BACK AND ANOTHER WAS SENT TO ME. THAT LAMP ALSO GAVE THE SAME RESULTS. I CALLED CHUCKS ELECTRONIC REPAIR AND A VERY KNOWLEDGABLE TECHNICIAN RESPONDED TO MY HOME. IT WAS DISCOVERED THAT THE POWER SUPPLY BOARD WAS BAD AND THAT THE LAMP NEVER NEEDED TO BE REPLACED. I SPOKE WITH REPRESENTATIVES AT MITSUBISHI SEVERAL TIMES AND THIS WAS NEVER EXPLAINED TO BE A POSSIBITLY. THE TECHS AT MITUSBISHI BASICALLY JUST READ FROM THE OWNER MANUEL AND HAD NO IDEA WHAT THEY WERE DOING.
Posted on May 15, 2008
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
  • 1039 Answers
SOURCE: mitsubishi wd 52725 lamp troubles
You can use Mitsubishi 915p020010 or Osram E023. Remove the front and clean the lense using only a clean microfiber cloth. dirty lense main cause of dark picture. The lamp could be incorrect wattage.
Posted on Apr 25, 2009
  • 72 Answers
SOURCE: just replaced the lamp on my mitsubishi wd-65732 2
if you used an OEM lamp rather than an original ,it may have gone out. The more expensive original bulbs last longer
Posted on Jun 07, 2009
Slinteriors
  • 8617 Answers
SOURCE: tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Posted on Jun 10, 2009
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Tv turns on but no picture or sound
If its a Mitsubishi and doing this some of the lights on the front should be on or blinking?
Apr 26, 2012 | Mitsubishi For Projector Lamp Wd-60638ca...
I installed a new lamp, but my tv doesn't come on. The lamp light keeps flashing yellow.
Could be Bad Ballast,or defective cooling Fan, Lamp fan.
Encompass Parts Distribution 1-800-638-3328
If Lamp Fan is not running when lamp trys to come on TV will turn off in order to protect the Lamp
The Ballast Board is what turns the Lamp ON.
Sep 24, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Turned on tv, no picture, only sound
the problem is likely the projection lamp .. you can replace that yourself if you are handy .. you must unplug the set and make sure everything is cool ...avoid getting finger prints on the new lamp ...here are a few places where you can get a new lamp ... you can also see what it looks like on this site ...
http://www.bluestar-online.com/Mitsubishi_Model_WD_65731_Replacement_DLP_Lamp_p/wd-65731.htm?gclid=CLb9k4zf-6ACFdk55QodwT3dxw
the lamp is likely in a cubby in the back of the set (where you used to see the bright light) ...
the lamp is mounted in a cage ... you can get the lamp already mounted in a new cage from here ...
http://purelandsupply.com/WD65731-Mitsubishi-DLP-TV-Bulbs.html
......it costs more mounted but its easier to change and you will need a new cage if yours is damaged .. from the site above you can see what the cage looks like with the lamp already mounted ..
your lamp is a model 915p049010 ... that is available thru amazon at a good price here:.(includes cage)........
http://www.amazon.com/Mitsubishi-915P049010-Lamp-DLP-TV/dp/B001AJ8RAA/ref=dp_cp_ob_e_title_0
Apr 10, 2010 | Mitsubishi WD-65731 65" HDTV
WD-65732 has audio but no picture. Sound like
Replace Lamp Call Mats Electronics 1-800-628-1118
Mar 25, 2010 | Mitsubishi WD-65732 65" Projection HDTV
Just replaced the lamp on my mitsubishi wd-65732 2 months ago and now have no picture and i just the red lamp light on. please help
Jun 07, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi WD-73735 Television Logo
97 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
