Vacuums Logo
Tony Overdirth Posted on Jul 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does green/red clean sensor light start green, then turn red and stay red?
The green/red clean sensor light starts out green when turned on, immediately turns red when vacuuming starts, then stays red, even when vacuum is held off of floor
thinksewfast
Level 2:
Habit-Forming:
  • Expert 89 Answers
  • Posted on Sep 12, 2016
thinksewfast
Expert
Level 2:
Habit-Forming:
Answers
89
Questions
0
Helped
32512
Points
121
That can mean the bag is full.
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Sep 22, 2007
SOURCE: Embeded Dirt Finder
check out the switch that activates it. go to thehooverstore for a complete listing of hoover machines. I'm sure you'll find your machine listed along with an exploded diagram of the machine
Anonymous
  • Posted on Jun 20, 2008
SOURCE: Electrolux Epic 6500SR Full Bag sensor working, Does not Reset properly
The problem was a sticking switch that was not being reset. The vacuum on/off switch mechanism is comprised of two switches. One is the main switch that turns the vacuum on and off. The second is a shut off switch that gets tripped when the full bag sensor is engaged. This second switch is supposed to get reset when you push the on/off switch on the outside of the machine. The full bag shutoff switch was stiff and it, therefore, was taking a couple of presses of the on/off switch to move the shutoff switch back into the running position.
Anonymous
  • 3 Answers
  • Posted on May 29, 2009
SOURCE: Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
Anonymous
  • Posted on Jun 27, 2010
SOURCE: hoover windtunnel dirt finder light stays red
I'm not sure about a 3 month old vac, I'd probably go the warranty route. However, for the older vacs thy start getting false positives. The sensor is simply a microphone hooked to a computer chip detecting sounds of dirt entering the bag.
To rig it to start working, you'll need to remove the tool accessory tray and elbow that enters the back of the vac, and attached to the bag. This will reveal the microphone at the elbow, and wire that runs into the bottom area of the vac. When on, a large amount of air comes from the bottom screw and area where the wires enter. My fix was to clean up the microphone contact points a little bit with a screwdriver, and then leave the vac running while putting in dampering in the hole at the bottom, and around the back of the elbow. Cotton balls and electrical tape at the bottom hole, and napkins around the outside of the elbow (wedged between the back of the vac assembly and elbow did the trick). The schematic for the vac is here: http<colon>//www<dot>vacsrus<dot>com/CartGenie/pg_U6485900<dot>asp
Look for micrphone.
Anonymous
  • 10 Answers
  • Posted on Jul 28, 2010
SOURCE: I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
1helpful
Panasonic Dirt Sensor vacuum repair
Dirt Sensors are sensitive. It doesn't take much to set them off. Try pulling back on the handle to raise the brushroll a few inches off the floor so you know it's not detecting particles of soil. If the light doesn't turn green it may have dirt on the sensors and need to be cleaned.
The dirt sensor light stays green. It won't turn red, even when I know I'm picking up a lot of dirt.
The Board(46851083) is No Longer Available
The EDF Duct (47823004) EDF= Electric Dirt Finder is $20.40 from
http www searspartsdirect com model part u6485900 0517 0645000 50039309...
You can test the board by crossing the 2 connectors to "close" the circuit for the mic (small black and blue wire) while vac is running and light should go to red every time you complete the circuit. WARNING: There will be exposed electrical points on board that could cause an electrical shock!!! or damage to board if not just crossing mic connections.
I have the G series Kirby silver vacuum, I was vacuuming and started to smell some burning. Looked down and my green light was off also. What could it be? PLS HELP
Your belt is burning and will eventually wear down and break. The green light comes from copper brushes on your roller creating an electrical current that lights the little green light. As long as the roller is turning, the light will stay on. There may be something jamming the roller (hair, string, paper, etc). Clean the roller off and replace your belt. If you don't replace the belt it will break soon enough. Once you start smelling the "rubber burning" smell it's and indication that your belt has deteriorated at some point and has a weak spot in it. Clean the roller and replace the belt and it should be fine.
3helpful
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Uh70015 dirt sensor stays on green. Goes on red for about 5 seconds then green. Can clearly see the floor is dirty and it is picking up stuff.
ahh the good ol electronics on vacuums selling the product again...
not to worry, your feature is working properly, your vacuum is working fine too.
Imagine if you will making a circle with your pointer finger and your thumb. Now put a string or thread across in a straight line there. The string would be the size of the beam of light that the sensor uses. Your finger and thumb are about the size of the tube that the dirt and dust is passing by. Unless the dirt passes and cuts through the beam of light, then it will register. otherwise if it passes around the beam of light, the sensor thinks your carpet is clean.
The opposite sometimes will happen too where it will stay constant red. That means that the sensor is completely covered in dirt and will not register anymore.
Hope this helps.
Mark
Scooba battery light turns red as soon as irobot starts
Do you leave the battery on charge long enough? Try 4-hours up to overnight. If so, then the battery is probably at the end of it's useful life. Getting a new battery depends on cost versus life expectancy of the robot and whether it does the job you want it to do.
24helpful
4answers
Embedded dirt finder light stuck
The Hoover uses a small microphone that is positioned in the plastic housing that the end of the hose fits into, just behind the bag compartment. What happens is that when dirt comes up the hose and hits the 90 degree corner, just before it enters the bag, the microphone picks up the sound and transmits that info to the electonics that controls the lights. Sometimes the microphone will stick and the red light will stay lit. If you take a screwdriver and give the microphone area a sharp tap with the handle of the screwdriver, this will often jar the microphone and it will begin working again. If not, it may need to be replaced. NOTE: this function does not affect the cleaning efficiency of the vacuum. Your vacuum will still work normally whether the dirt sensor is working or not. It is a totally unrelated function to the vacuum itself.
Dec 31, 2007 • Vacuums
3helpful
Dirt finder
The sensor may be bad, or it may be coated over with dirt. Re,ove the hose at the back of the vacuum, the head of the sensor is down inside that opening, reach in there and clean it off and see it that corrects the problem, if not replace the sensor.
Battery light goes red after bumping/backing up
try this: turn it upside down and run it-then bump it to reverse it...same result?
Embedded Dirt Finder green light won't come back on - stays red
The dirt sensor is a motion detector. After it gets dirty it will either stay red or stay green. You can have the vacuum serviced at your local vac shop and possibly get this fixed. Sometimes they are as good as new and sometimes they are not repairable. It will not effect anything else though.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
