Question about Kenmore 27032
Kenmore Washer won't spin
I have a Kenmore 110.92281800. The washer had loud squeak when starting spin cycle, but would go away once spinning. Now it wont spin, although the motor is turning. I checked to see if the coupler was broken. The pins on both sides of the coupler seem fine. I expected to see them broken off. What next? Gearcase? If so, is this repair worth it? Washer is maybe 15 years old, was here when we moved in. Thanks.
  • 3 more comments
  • pwlong19 Jul 11, 2009
    Yes, I'd like to fix it. What parts will be required? The clutch is about $40 and the brake and drive tube about $100. Is the gearcase OK? One concern is do I do this repair with the age of the washer. Thanks.
  • pwlong19 Jul 12, 2009
    The clutch spins, so the coupler and gearcase seem fine. Clutch too? Ill plan on taking this apart next to assess the brake and drive tube assembly. What do I look for to check if this is bad or a bad clutch?
    One more clarification that may help the diagnosis: before stopping spinning, the spin cycle was slowing down and seizing yesterday, then tripping the breaker. At first, I could restart the washer and it would work but now the motor spins the clutch but the tub and agitator do not move although the agitator starts to move a little. Once I get it apart, how will I know what is broken/needs replaced? Thanks.
  • steve
    steve May 11, 2010
    Your brake/clutch has locked up. It is replaceable Let me know if you want to try and replace it.
  • Kenmore Master
  • 3,361 Answers
If the clutch spins and the transmission does not it is a bad clutch.
While you have it down replace the direct drive coupling also.
And yes, if the machine is in good condition otherwise it is worth doing the repair.
Posted on Jul 12, 2009
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
I have a kenmore stacked washer/dryer that squeaks in the spin cycle. What could it be??
i had that problem too. i noticed that is was not flat on the ground. You can also try putting oil on it.
Dec 09, 2012 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Squeaky basket and loud vibration when in spin cycle.
Bearings worn, belt loose and probably motor brushes.
May 17, 2012 | Kenmore HE3T Washer
Kenmore top load washer making loud noise in spin
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 02, 2009 | Kenmore 22422 Top Load Washer
Kenmore front loader washer squeaks in washer mode and shakes in spin.
shocks made of plastic squeaks, a little greese may help
Nov 08, 2008 | Washing Machines
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Kenmore 27032 Logo
274 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
