Question about Brother MFC 210C All-In-One InkJet Printer
LC 900 Bk Brother Ink Cartridge Pressure Release Button
The release valve has accidently been pushed in and now stays stuck and will not release.
Can it be installed with button in or will it cause problems?
How can button be released again?
    Scholar:
  • 82 Answers
It should be fine. That is an air release valve, which is depressed by the printer when the cartridge is installed. The cartridge may leak when out of the printer though, so be careful. No problems in the printer.
Posted on Jul 23, 2009
How do i change my ink cartridge on my mfc-295cn
Hello and welcome to FixYa;
  1. Open the ink cartridge cover. If one or more ink cartridges is empty (for example Black), the LCD shows "Cannot Print (Replace BK Ink)" or "B&W Print Only."
  2. Press down on the release lever to unlock it and take out the ink cartridge for the color shown on the LCD.
  3. Open the new ink cartridge bag for the color shown on the LCD, and then take out the ink cartridge.
  4. Turn the green knob on the protective yellow cap clockwise to release the vacuum seal, then remove the cap (1). You must hold the ink cartridge as indicated in the picture below.
  5. Each color has its own correct position. Insert the ink cartridge in the direction of the arrow on the label.
  6. Gently push in the ink cartridge until it clicks, and then close the ink cartridge cover.
  7. The machine will automatically reset the ink level.
I am sending you the link that shows you illustrated pictures to help you through this.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000030/faq000230_012.html?reg=us&c=us&lang=en&prod=mfc295cn_all&Cat=7
You should be good to go!
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
If you need further help, reach me via phone at https://www.6ya.com/expert/carolyn_427ff26936286336
May 30, 2011 | Brother IntelliFax Fax/ Phone/ Copier
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
Ink cartredge stuck in printer
turn off printer hold down transfer button and left arrow button at the same. Then turn in Printer, you should hear it make some noises . Open the side push on cartridge to see that it is locked in tight. Hit the green "release" button and cartridge should come loose on its own.
Apr 27, 2009 | Kodak Easyshare Printer G600 Thermo...
I want to install ink cartidges and do not know where to begin. I have misplaced my instructions
To install your Brother machine#s ink cartridges, follow the steps
listed below:
1. Make sure that the Brother machine#s power is turned on.
2. Open the ink cartridge cover. This cover is located on right-hand
side of the Brother machine#s front panel.
3. Pull down the four lock release levers. There is one lock release
lever for each ink cartridge.
4. Take the ink cartridge out of its protective bag.
5. Carefully remove the yellow protective cap from the ink cartridge.
- DO NOT touch the side of the ink cartridge covered by the yellow
protective cap.
- Take care when removing this cover to prevent spilling ink and
staining your hands and clothing.
- If the cartridge cover comes off when you open the bag, the cartridge
will NOT be damaged.
6. Install each ink cartridge in the direction of the arrow on the
label.
- Please note that each color has its own specific position. These
positions are indicated by the colors of the four lock release levers.
Do not install an ink cartridge in the incorrect position, as this can
cause print quality problems.
7. Lift each lock release lever and push it until it clicks into the
closed position.
8. Close the ink cartridge cover.
- If the LCD shows #Install Black,# #Install Cyan,# #Install Magenta,#
or #Install Yellow# after you install the ink cartridges, please verify
that you have installed the cartridges correctly.
NOTE:
* DO NOT remove the ink cartridges from the Brother machine unless you intend to replace them. If you do, it may reduce the quantity of ink left in the cartridge, which may cause the Brother machine to miscalculate the amount of remaining ink.
* DO NOT shake the ink cartridges. If ink stains your skin or clothing, wash the affected area with soap or detergent immediately.
* DO NOT repeatedly insert and remove the ink cartridges. Doing so may cause ink to seep out of your cartridges.
* If you mix the colors by installing an ink cartridge in the wrong
position, clean the print head several times after correcting the
cartridge installation.
* Once you open an ink cartridge, install it in the Brother machine and use it up within six months of installation.
* Use unopened ink cartridges by the expiration date listed on the
cartridge package.
* DO NOT dismantle or tamper with the ink cartridge. Doing so can cause ink to leak out of the cartridge
Apr 20, 2009 | Brother MFC 240C All-In-One InkJet Printer
Where is the ink cartridge?
It is on the FRONT RIGHT PANEL, See below. Bud
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in. If the display continues to show NO CARTRIDGE, continue to Step 2.
  2. Open the ink cartridge cover. Pull the lock release levers down and take out the ink cartridges.
  1. Reinstall the ink cartridges and lift and push each lock release lever until it clicks, then close the ink cartridge cover.
Jan 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Changing the ink cartridge in Epson Stylus CX4200
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
May 15, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Refill brother LC51Y inkjet cartridge
see here:
http://www.hstt.net/refill-faq/brother.html#LC-1000%20-%20Refill
(use google translation german)
for c/y/m refill 15ml dye ink
for bk 20ml
Apr 22, 2008 | Office Equipment & Supplies
Refill ink Cartridge
see link:
http://www.hstt.net/refill-faq/brother.html#LC-1000%20-%20Doku
(the lc1000 is the same as the lc51)
Refill a max of 12ml for Y/C/M and 20ml for bk.
BTW
brother has changed the inside of the carts. So plz check carefully the pics if your cart looks the same. If it looks different you should drill the hole near the upper valve (the one with the white plastic)!
Nov 20, 2007 | Brother Black Inkjet Cartridge for LC31BK...
How To Refill?
Harry, you can use every DYE ink for brother printers. DO NOT use pigmented ink due to clogged filters inside the printhead!!!! The carts for mfc210 are filled with 20ml for BK and 11ml for C/Y/M. I use to refill 20ml only ink for bk and 10ml ink + 1ml printhead cleaner for C/Y/M. See here how to do that (LC900 refill): http://www.hstt.net/refill-faq/brother.html#LC-900 Refillen (Simply drill a hole into the brother brandname and leave it open!) I use a 20ml syringe and 3 12(10+2)ml syringes from the drugstore (ask your doc! It may be cheaper ;-)
Sep 26, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
190 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
