Might be cartridges are clogged,go to printer properties, perform clean nozzles, check quality.. repeat 2-3 times to get good quality, if you are not satisfied, replace cartridge/s
try ping xxx.xxx.xxx.xxx (printer IP address. if you get a answer back (no timeout). then you have a good connection.
go to start>>printer and faxes>> add a printer.
select network pirnter, and let the operating system find the printer.
if it find it, then install the driver on the PC try a test page.
if not, then you have to install the printer as local.
select to creat a new port, with standard TCP/IP port. insert the printer IP address.
install the pirnter driver and try a test page.
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
use a flash light check all paper path, specially the area around the toner. all you need is a small piece or other (dust). There is a micro switch that detect the paper travel. so if anything preventing the switch to open, you will get error message.
after that, open the toner door, reseat the toner and close the door. the pirnter should return to normal.
Select a picture (pres rev button) Then press the Del button twice. The display gives you the option to delete all the pictures or multiple pictures. Hank
Give "restore factory settings" when you give this you will be asked for security code & all your contents which are available in the phone memory will be erased including contacts,messages,pictures etc ...
