Question about Acer AL1711 17" LCD Monitor
Monitor Displays My Acer monitor all of a sudden has developed messed up smudged colors and no lines for separation of emails and other columns. The icons on the task bars are either dull or non existant. Help..... Thank you for any help you can give.Mike
  • 749 Answers
As much as we want to help you!!! we also need a more detailed information of your problem! if you happen to have a friend with a computer then, ask for a favor to try your monitor on their computer! if your monitor works fine on their computer then your problem might be with your computer's VIDEO CARD.
Posted on Nov 15, 2007
Hello, I have a Dell U2711 monitor that now displays just a bright white screen. I was using the monitor, when it started getting brighter and developed a series of vertical lines in a repeating pattern...
Dell technical support number by dial Dell helpline number 1-80-243-0019 to get Dell customer support services to repair Dell Computer, Laptop, Printer.
Apr 14, 2017 | Dell U2711 27 inch LCD Monitor
Powermac screen developed fine black grid and won't operate properly
Isolate the problem to see if it's the screen or video card by connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok without a problem then your original screen is bad and your video card is good. If the Borrowed monitor displays the same problems as your original then your video card inside the computer is bad.
May 29, 2012 | Apple Powermac G4 Quicksilver Logic System...
Screen with a weird flickering and coloring on Acer 5715Z laptop
To determine if he video card is faulty, connect an external monitor to the laptop's external video port, then power up the external monitor and then the laptop. The video info should automaticall switch to the external monitor. If you see anormal Windows image on the monitor then the video card is OK and the fault is with the LCD screen, could be the video cable/connector. Try reseating the video cable/connector to the motherboard.
If the video card is faulty and because it is part of the motherboard it is extremely dificult to repair, usually a replacement motherboard is required. This may not be a cost effective solution depending the age of the laptop. You could remove the hard drive from this laptop and insert it into an USB hard drive adapter case and use it as an external USB drive.
Aug 16, 2009 | Acer Computers & Internet
My monitor suddenly altered the colors on the screen; white background now appears slightly pink, green appears black. How can I make adjustment to correct the color?
your monitor is either going bad or your display setting are messed up.use the buttons on the front and mess with color option if that don't work then you need a new monitor
Aug 05, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Scrolling colored lines on the monitor, overlaying the screen.
You either have extremely screwy drivers, a bad cable or your monitor/panel is shot. Replace any of the above to resolve the issue.
May 29, 2009 | Acer X193W LCD Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
Pinkish monitor
the monitor is on its way out ,
time for a new one
Mar 29, 2008 | Computers & Internet
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Acer AL1711 17" LCD Monitor Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
