Question about Phoenix Gold Tantrum 1200.1 Car Audio Amplifier
1200.1 tantrum amp can it run 1.34 ohms
Pg 1200.1 tantrum amp can it run 1.34 ohms
  • 66 Answers
Depends on how long and how hard you push it....
It can easily run 2 Ohms, so 1.34 ohm is 67% less resistance than it should carry. This means that you wont be able to push it too hard or too far.... it's too much of a load....
Sorry.
Posted on Jul 11, 2009
Can i run 4 rf r165x3 speakers which are 4 ohm to a pg 250.2 amp if so how to wire them to 2 ohm
If it can handle 2 ohm you can run in a pair. Hook one up to a channel then use a speaker wire from that one ( positive & negative) to the other + & -
Jun 01, 2016 | Car Audio & Video
Whats the best way to hook up 2-10'' 4 ohm dual voice coil to the d5 1200.1 amp
4x4 ohm voice coils can be configured to either run @ 1 ohm, 4 ohm or 16 ohm, while the amp needs to be dropped to 2 ohms, no lower, to be most efficient. if a single dvc sup could handle 1200 watts, then hjust run 1, with both coils positive and negative inputs connected to the amps output. if you needed both subs, you would lilely only get 600 watts, by creating a 4 ohm load by running both speakers to the amp positive to 1 ccoil, each speaker, an mjumper cable between the negative of 1sdt clils to positive of 2nd coins, and running both 2nd coil negatives back from both speakers to the amp negative. the 2nd wscenerio will result in less sheer wattwage, but will also provide cleaner power. you need to study ohms law and parallel versus serial wiring to accomplish the 2nd scenerio, or, just get 2 4 ohm single voice coil speakers that can handle 600 watts apiece.
Sep 05, 2014 | Diamond Audio D5-1200.1 Car Audio...
My outputs are not working and I need to know what are parts number. Mine are not readable. PG tantrum 500.2 thank you
phoenix gold uses parts made just for them. Chances are you would have to send it to phoenix gold to get it repaired anyway.
May 31, 2011 | Phoenix Gold Tantrum 500.2 Car Audio...
The ampe i got is the bp1200.1 is that 1200 watts in to one chanel can you tell me thanks
it is a mono (one channel) amp. it outputs 600 watts at 4 ohms (1x4 ohm speaker connected) and 1200 watts at 2 homs (2x4ohm speakers or dual 4 ohm voice coils in parallel).
Jan 31, 2011 | JBL BP1200.1 Car Audio Amplifier
XM-2002GTW Car Amp: i have 2 dual 2-ohms solobaric speakers and im try...
I researched your amp and it looks like its not even 2 ohm stable :( the problem with these companies is they lable there amps 1200 watts MAX, that means they tested the amp in a perfect enviroment and the amp fried somewhere in the ball park of 1200 watts, your best bet is to save your money and buy a nicer amp that is two or one ohm stable... that being said the best way to wire your subs is in series
May 17, 2010 | Sony XM-2002GTW Car Amp
I have a lanzar opti drive plus 500 old school,i have 2 12'' 1200 watt pyles,running in parallel at 2 ohm. when i bridge it at 2 ohm 1000 watts it blew my 40 amp in line fuse.
The 40 amp fuse is too small. 1000 watts = 12 volts @ 83 AMPS. Bigger power wire my friend. If you want to sell, let me know.
May 15, 2010 | Car Audio & Video
Where are the fuse on this amp?
The Tantrum 1200.1 is externally fused -- there is no fuse within the unit. Per the installation guide, it should have an 80 amp fuse between the amp and the power source.
Feb 18, 2010 | Phoenix Gold Tantrum 1200.1 Car Audio...
How well will a 1000 watt kenwood amp pump with 2 1200 watt suns
2 will push more air but be careful how they are wired so you dont go to low on the ohms your amp sees.That amp should be 2 ohm stable so read up on how to wire in series or parallel.
Sep 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
    ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
    Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
    Phoenix Gold Tantrum 1200.1 Car Audio Amplifier Logo
    142 people viewed this question
    Top Phoenix Gold Car Audio & Video Experts
    Jose Velazquez
    Jose Velazquez
    Hemant
    Level 1 Expert
    seankane89
    Level 1 Expert
    Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
