Question about Brother MFC 7420 All-In-One Laser Printer
TONER END OF LIFE - Brother MFC 7420 All-In-One Laser Printer
  • 133 Answers
Open the front cover and push option, start and 00.
wait until accepted.
once accepted then your printer should be fine.
Posted on Aug 11, 2009
Brother MFC 7820N Toner life end with new toner
I found the following post on another site. It appears to work. If you want to reset your Brother MFC 7820N machine so you no longer have the error message: Toner End of Life, do the following:
1. Open the front cover of the 7820N, that is, the cover that allows you to pull out the toner and drum, but don't pull out the drum/toner.
2. Push the button: Options (located on the left of the control pad).
3. Type: *00 on the keypad.
The Brother MFC 7820N should be reset and the Toner End of Life message should disappear. WARNING: This may void your warranty and ultimately damage your machine if you are reusing or refilling your cartridges, but you should already know that. Hope this helps.
Sep 07, 2010 | Brother MFC-7820N Printer
Toner Life End message on DCP-7040
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Jan 04, 2010 | Brother DCP-7040 Laser Printer
Change toner and it comes up with Toner Life End
Im think you leave the cover open and hold down clear
Jan 21, 2009 | Brother IntelliFax-2820 Laser Fax
TONER LIFE END BUT TONER IS NEW
first print out a help page. i beleive that this is in the reports section, scroll down to drum follow the promps the same for toner good luck brother sr tech
Jan 19, 2009 | Brother MFC 7420 All-In-One Laser Printer
Toner end life message
i solved the brother mfc8860 toner life end problem
hi guys my name is reedwaan. Im new at this site so please listen up
my brother toner i refilled with toner and inserted it. It said toner life end then i patched the windows close on the sides and still the same problem, then i removed the toner and loosened the two screws on the left by the gears then removed the cover of the gears.
Right at the back there is a funny looking gear with a spring behind it. All you have to do is pull the spring a little bit clockwise and push the gear back on hooking the spring into it so that the gear is spring loaded. close it up then test it, It took me a while to figure it out but i got it right.
NB*  The gear that you push on, is the toner reset gear and when you push it on make sure the teeth dont interlock with the second gear on the left of it. If you have any queries mail me on reedwaan@yahoo.com
glad to help out
Jul 07, 2008 | Brother MFC-8860DN Printer
Toner life end message flashes
did you reset the toner life?
open the front cover, press the option button, on the screen will display ''reset toner life 1 yes 2 no ''
press 1 and close the cover.
toner life reseted
May 06, 2008 | Brother MFC-7820N Laser Printer
Toner low, tone life end
There is a gear on the left hand side of the toner to reset the toner count this can cheated be rewinding it. Yes the design is to stop the refillers or at least slow them down a bit. If this fails purchase a new genuine toner but I have seen problems with the switch that resets the toner (Either the spring on the switch has popped off or the main board has failed).
Jan 10, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Jan 08, 2008 | Brother IntelliFax-2820 Laser Fax
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
135 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
