Question about Dryers
The heat sensor portion of my dryer went out. This is not the Timed Dry part. Do we need a repairperson to fix it?
    Brigadier General:
  • 4,088 Answers
Maybe. Heat actuated switch should be mounted on metal pipe of exhaust. You need to take front panel off to get to it. If you take the switch off, you can get a good unit to "click" by heating it gently with a match or lighter. The switch should be "closed" when cold. Probably, just replace it.
Posted on Jul 12, 2009
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Gas dryer does not dry in "timed Dry" setting
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 06, 2015 | Whirlpool LGB6300 Gas Dryer
I have an LG DLE0442W and its having some problems. Well first to turn it on you have to hold down the power button or the lights will just flicker and it went turn on. When you hold it down it turns on no...
I suspect two issues
1. Need new power button. Easy fix. Check out repairclinic.com or appliancepartspros.com for how to videos and parts.
2. Your sensor strips in dry my have either lint under them or dryer sheet residue on them throwing off the moisture sensor reading and shutting down dryer early.
May 07, 2017 | LG Dryers
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Hello! Is it possible to replace a heat sensor?
put it on timed dry to see if it does it if not the sensa dry is bad
Apr 19, 2010 | Kenmore Elite HE4 Electric Dryer
Sensor and timed dry isn't working. Dryer runs but never stops.
if the timer dont run on the timed dry setting the timer is bad.if it works on the timed setting but not the auto setting you have a heat issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 06, 2010 | GE Dryers
Dryer not heating or turning off
It can be multiple problems. First are you using it on sensor dry or timed dry? If it is timed try, it's possible your timer is not advancing. If you are using sensor dry it could be your sensor.
To test the timer, check for continuity across the timer. If it is open, replace the timer.
To test sensor, run the dryer on sensor with nothing in it, if the timer advances quickly, the sensor is not the issue. If it does not advnace, it could be the sensor.
The no heat issue; check to make sure you don't have a blockage in the venting or in the dryer. If there is no blockage, check your element. To check if the element is not heating up, check for continuity through the sensor.
Hope that helps.
Nov 16, 2008 | Whirlpool LEB6200 Electric Dryer
Maytag Neptune Dryer-stopped heating
first, check the exhaust, make sure every inch of it is clean on the inside. if there is any blockage, the heat will build up in the exhaust and a sensor will shut down the heating element.
Oct 27, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Amana ALE643RAW Gas Dryer
.hi with gas dryers the parts to look for are . the blower . will take longer to dry and noisy .The venting very important. The coils on the gas valve .Will cause the flame to only come on for a few minutes . then nothing so for that problem . replace the coils. Thanks the appliance doc
Dec 05, 2007 | Amana ALG443RAW Gas Dryer
Dryers Logo
81 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
