Question about Karcher G3025OH Pressure Washer
No water pressure
Have pressure washed for two days, no problems. today, can not get any water pressure
  • 174 Answers
If it is not leaking, you need to lubricate the unloader valve. Contact me at firehead@rogers.com if you are not sure how
Posted on Jul 12, 2009
My 99 tacoma 2.7 auto down shifted from overdrive to 2nd or 3rd gear while i was going 70mph. never happend befor. any ideas
One of the connectors in the wiring harness could have water in it causing connection problems.
Feb 28, 2013 | 1999 Toyota Tacoma PreRunner
Maytag Neptune TL washer overfilling
yes i would agree the water valve is defective as if unplugged it should close,but also sounds like a pressure sensor or pressure hose problem that is also defective too due to the fact that it should at least start the wash cycle even though the water doesn't stop filling,so also it could be the central control unit,pressure switch or pressure hose
May 07, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Hi. I have a Whirlpool Gold Ultimate Care II Quiet Wash plus top loader washing machine. Today as the water went in to rinse the wash it flooded out across the floor from underneath. Is there a filter I...
No problem with Filter.
Pressure switch is not working, it is not sensing the water level. There could be one more reason can cause this issue. Please check the Pressure HOSE whether is punchered or not.
Sep 16, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I BROUGHT A BUSH WASHING MACHINE WM-1470TVE HAD IT 2 DAYS AND KEEPS COMING UP WITH Err5
Hi.
Err 5 is water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water level switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Oct 29, 2010 | Washing Machines
The dishwasher did a full cycle three days ago yet today it is just beeping and making gurgling noises now and will not start Any ideas as to what the problem might be
Check whether the water flow to the machine is OK. Try adding water
to the wash chamber manually and run the cycle. If the noise stops
it must be air trap. The machine should complete the wash also after this.
Still the problem continues the water pump to be checked.
Oct 04, 2010 | Dishwashers
The washer overflowed today. Does not seem to be
Overflowing is caused by the pressure switch, it needs to be replaced. Regarding the cold water, it is a water valve issue.
Both needs to be replaced.
Nov 02, 2009 | Washing Machines
Hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Sep 06, 2007 | Washing Machines
My friend has this washing machine and has to turn the water off and on
Need more info not sure i understand but sounds like a pressure switch or water valve problem
Aug 25, 2007 | Haier HLP21E Top Load Washer
Karcher G3025OH Pressure Washer Logo
247 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Tim Venetis
Are you a Karcher Garden Expert? Answer questions, earn points and help others
