Question about Sony VAIO Digital Studio PCV-RX550 PC Desktop
My PCV-RX550 has 60GB, but 15 is C drive and rest on D. Most applications run on C. 1/2 D is empty. CRAZY! I want to add to the C drive side, and not disturb, e.g. loose anything. How do I do this.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
1: use partition magic and for make an drive of extra space of d:
2: if u want to resize ur c drive use Norton Ghost 2003 for making wiindows bakup and make in to e drive and install new windows
del c drive and make again of ur reQUIRD size of c during installation
after completion of installatoin install Norton Ghost 2003 again and restore ur prv windows vid all application and data
Posted on Jul 11, 2009
  • 112 Answers
Any partitioning software will allow you to alter the sizes of your 60gb drive without loosing data.
There are lots of options to choose from. Paragon software has a free version you can download:
http://www.paragon-software.com/home/pm-express/awards.html
Starts after several cranks when cold
engine temperature sensor ? On a cold start the sensor tells the ECU it's cold so the ECU adds more fuel until the engine is warm.
Mar 02, 2015 | Cars & Trucks
I need to know how many qts of transmission fluid goes in a 1998 ford windstar?
Application: With automatic transmission
AX4S transmissionTotal refill - 12.3 quarts.
May 10, 2011 | Ford Windstar Cars & Trucks
We have 1998 chevy cavalier and is burning a lot of oil, per 1000 miles we ad 1 litar of oil., we did check for pcv valve but looks like this vehicle does not have pvc valve that we caqn check , can you...
If Pcv valve is not working correctly car will run real bad starving for air. And check engine lite will come on. I would add one liter of Locus oil stabalizer and drive it, Sounds like it's about time for a overhaul. best of luck to you.
Apr 07, 2011 | 2003 Chevrolet Cavalier
My laptop is running very slow and from yesterday i cannot make call from skype or gtalk other person cannot hear my voice but i can hear his voice
1. Let your PC boot up completely before opening any applications.
2. Refresh the desktop after closing any application. This will remove any unused files from the RAM.
3. Do not set very large file size images as your wallpaper. Do not keep a wallpaper at all if your PC is low on RAM (less than 64 MB).
4. Do not clutter your Desktop with a lot of shortcuts. Each shortcut on the desktop uses up to 500 bytes of RAM
5.Empty the recycle bin regularly. The files are not really deleted from your hard drive until you empty the recycle bin.
6. Delete the temporary internet files regularly.
7. Defragment your hard drive once every two months. This will free up a lot of space on your hard drive and rearrange the files so that your applications run faster.
8. Always make two partitions in your hard drive. Install all large Softwares (like PSP, Photoshop, 3DS Max etc) in the second partition. Windows uses all the available empty space in C drive as virtual memory when your Computer RAM is full. Keep the C Drive as empty as possible.
9. When installing new Software
Feb 05, 2011 | Acer Computers & Internet
How the heck do you get the side panel off Sony
From the Sony manual:
http://www.docs.sony.com/release/PCVRX670_SR.pdf
Removing the Side Cover
You must remove the side cover to access the system board, add-in cards,
power supply, battery, memory, and internal drives.
1 From the rear of the unit, pull the metal tab shown in the next
diagram. (Upper right corner)
2 Pull the top of the cover away from the unit about two inches, then
gently lift out the cover.
Aug 01, 2010 | Sony VAIO Digital Studio PCV-RX580 PC...
Need instructions for the game count across by Cadaco
Count Across™ Instructions
OBJECT OF GAME
The first player to place four chips in a row, either vertically, horizontally or diagonally wins the game.
Contents
1 Wooden Tray with Content Holder 1 Clear Plastic Slide with holes
1 Two-sided Number Board
25 Purple chips 25 Green chips 1 pair of dice
Set-Up
Each player selects a set of chips (purple or green). Decide which side of the number board to play, Addition Only (blue side) or Addition & Multiplication (red side). Line up the Number Board underneath the Clear Plastic Slide so that the numbers line up through the holes. The raised tab on the Clear Plastic Slide should be face up. Slide the Number Board and Clear Plastic Slide into the Wooden Tray together. The Number Board should rest underneath the Clear Plastic Slide. Each player rolls the dice once to determine who plays first. The player with the highest roll goes first (Player 1).
Addition Only Play
The Player 1 rolls the dice and adds the two numbers on the dice. Places one of your chips on the Number Board over an empty number space that matches the total of the dice.
Example: A play a rolls a 5 and a 3. 5 + 3 = 8
Player 1 finds an empty number 8 space on the Number Board and places a chip into that slot. Player 1 may choose any open 8 on the number board, but may only place one chip on the board per turn.
Player 2 then rolls the dice and places a chip in a space on the number board that matches the total of the dice. Play continues back and forth until one player gets 4 chips in a row, horizontally, vertically or diagonally. A player can remove an opponent's chip from the board in the following instances:
• If a player rolls doubles, they may remove an opponent's chip if it occupies a space that matches the total of the dice. Example: A player rolls a 4 and a 4. 4 + 4 = 8 and if an opponent has a chip in an 8 space on the Number Board, the player may remove the opponent's chip and replace it with his or her own chip.
• If a player rolls the dice and there are no empty spaces matching the total of the dice, the player may remove an opponent's chip that occupies a number space that matches the roll (if only the player's chips occupy those spaces). Then the play ends.
Addition & Multiplication Play
The rules are identical to the Addition Only play, except on each roll players may choose to either Add or MUltiply the numbers rolled. Example: A player rolls a 5 and a 3. The player may do one of the following:
• Add the dice together (5 + 3 = 8) and place a chip over an empty 8 space on the number board
• Multiply the dice (5 x 3 = 15) and place a chip over an empty 15 space on the number board
Warning! Do not throw out the Content Holder. It serves as a platform for the number board as well as storage for the chips and dice.
Jun 19, 2010 | Cadaco Count Across Game
Going thru coolant like crazy but theres no leak. we done so much so far. we put a water pump in and a therpasat in and sencer in and intake gaskets
Well first off, since you have replaced many parts, perhaps you have air in the system. Also check the oil to see if it looks like chocolate milk or is extremely high (indicating a blown head gasket).
While system is cold, add coolant to the radiator (if applicable) and the coolant tank. Then start the vehicle and turn the heater on high heat - full blast. Let run for 15 minutes or until the engine begins to overheat or the coolant tank become empty. Let the vehicle cool down (30 minutes) then repeat until it coolant level doesn't drop or engine doesn't overheat.
Now go for a test drive for about 10 - 15 miles make sure to take hills and highway/freeway. Let vehicle cool down and recheck coolant tank and radiator. If level has gone down then something is wrong. Perhaps the thermostat is in backwards.
Jan 06, 2010 | 2003 Pontiac Grand Am
My computer fan is very noisy, driving me crazy. PCV-RS7200
This can happen on most computers and is not limited to sony.
It does sound like the psu fan may fail. Although not recommended by everyone you could switch off the computer and unplug it. take it somewhere that you can blow out the psu
Remove the cover of your computer and with a can of compressed air meant for computers (dont poke the nozzle inside the psu ! ) blow out any dust bunnies or other unwanted creatures that may have set up home. Good time to blow out the rest too !
Then take a can of WD40 and put a small squirt through the psu fan opening on the back.
Re-assemble the computer and switch on. you may find that after a few moments it does quiet down,
This is usually only a temporary fix.
If you are competent you could remove the psu and replace the fan yourself (they are usually a common size) If not then a local repair shop may be able to do it for you.
Worst case you are looking at a new psu but for the most part you should be able to take it anywaher to have a new one fitted in minutes.
They are not too expensive and if you do change it then ask for a larger capacity in the power rating. EG if yours is a 300W psu it is always better to get say a 400W or 500W
Aug 20, 2009 | Sony VAIO PCV-RS530G PC Desktop
Computers & Internet Logo
139 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
