Televison & Video Logo
A
ADAMS Posted on Jul 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED TO REMOVE THE PARENTAL CONTROL WE FORGOT THE PASSWORD
FORGOTTEN PASSWORD NEED TO REMOVE PARENTAL CONTROL SO WE CAN WATCH DVD'S
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jul 19, 2015
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067273
Points
28436
Return to the original setting functions.
1helpful
Parental controls
HI,
Do the following for unlock the parental control. For this you should need the remote for the DVD payer.
1. Press the set-up button on the remote (set-up display will come on the TV screen )
2. Using Right arrow button or Left arrow button select DVD Setup menu
3. Using Down arrow select Parental control and press Enter button
4. now you can change the parental rating using up down arrows
If it ask for password the read the following carefully and do the same and enjoy your videos.
PARENTAL CONTROL LEVELS 1-8
The Parental Lock allows you to limit the use of your DVD Player to only those DVD discs that do not exceed the rating you specify. When the Parental Control is set, DVD discs that support this feature will play only after the password has been entered. However, typically only discs produced by major entertainment companies support Parental Control. Discs not supporting this feature will be "immune" to Lock-Out. When you attempt to change the Parental Control setting, you are prompted for a password. This of course makes sense, as this option would be useless if your kids could enter the Setup Menu and disable it! If there is no user password set, you'll be prompted to enter a new password. Choose a 4-Digit numeric password and write it down in Case you forget it. Key in the password and press ENTER. After the password is set, press ENTER on the CHILD option. You can choose from 8 levels of Parental Control, corresponding to the standard rating system in the USA. The available levels and their equivalent ratings are listed to the right.
PASSWORD - CHANGE
Here is where you can set an additional password to the default factory password. The procedures to change an existing password or enter a new password are the same - you must enter the OLD PASSWORD, then key in your new password twice to confirm. If you are entering a new password, or replacing a password you have forgotten, use the factory default password of 3351 as the OLD PASSWORD. If you are changing a previously entered password, you may enter that value as the old password.
A. Remember to keep in mind that the key to the the factory default password of 3351
B. Once the factory password has been changed, you should keep the password written in a safe location as a reminder if needed
Ajin
1helpful
4answers
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Forgotten parental control password on apple laptop
Go into an apple store and have them reset it
My son forgot his dsi password. What do we do next?
Hi.
Go into system settings and navigate to parental controls, tap on yes to change parental controls. Where the DSI asks for the password tap on "I forgot", it should then take you to the secret question page. Enter the secret question and you should be able to reset the password. If your son has forgotten his secret question again tap on "i forgot". It will then give you an 8 digit code. Leave it on that screen for the time being. Don't tap OK.
Post that code here and I should be able to provide you with a 5 digit code so you can reset the password and clear the parental settings.
Regards.
1helpful
Forgot passcode for parental settings.
Put the DVD in the PS2 and when the prompt for the password appears, press SELECT to bring up the delete password screen and enter the code 7444. Then register a new password.
6helpful
Can't Reprogram the TV Guardian code
Forgotten Parental Control password can be bypassed/cleared by entering "788444" even if 4 digits "----" appears, then press ENT to clear the current password. You can then enter a new parental control password.
PARENTAL CONTROLS WINDOWS VISTA MEDIA CENTER
Hi, I recently wrote a program to easily crack ANY Windows Media Center Parental Control Access Code. On a fast enough computer this can be done in under a minute. The program can be downloaded at http://www.mediafire.com/file/uzfzwmmuinf/MCPC-Bruteforcer.exe -- Enjoy!
2answers
How do you reset forgotten parental control password?
need password reset...also, forgotten how to enter password...MODEL NUMBER IS PDV-228...PLEASE HELP!!!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
