Question about 2wire 1800HG Router (RG1800HG00)
1800HG DSL modem/router: Cannot access any of the setup pages.
My 1800HG powers up just fine, and the 4 ethernet ports function properly as a home network. The device worked just fine about 2 months ago before I moved. I have changes ISP's and in order to make the dsl part of it work I need to access the various setup pages within the router/dsl modem. I cannot though. Every different page I enter that is supposed to take me to the options simply loads a blank page;
192.168.1.254
http://gateway.2Wire.net
http://gateway.2wire.net/setup
http://homeportal/setup
homeportal/setup/cdless.html
homeportal/management
There are no other devices connected to the 1800HG. Just my PC, the power cord, and the DSL phone line. The DSL light will flash green then turn solid orange and stay that way. How can I access my options page?
  • Angelo Valentino Montalbano
    Well almost every time, it's one of these 3 numbers. 192.168.0.1 192.168.1.1 192.168.2.1 Try those and the password is usually "admin" If those don't work then go to Start>Run>Cmd then type: ipconfig look for the default gateway, enter that number into you browser. Should do the trick.
  • 331 Answers
You have to set the unit to default hold the reset button for about 30 seconds the small hole
Posted on Jul 11, 2009
My computer mouse and keyboard not functioning well. I replace the keyboard but only last a month.
Hi jhunix,
I'm going to need even more information; The devices that use PS2 connections, which device is it, and how many of those devices do you have?
One thing that might be a problem, if the issue you see is intermittent, I would check the PS2 connector and see if the pins are bent or broken. PS2 connector pins sometimes will bend or break and this can cause some connection issues if not completely stop the keyboard/mouse from working... Also given the age of your PC the PS2 port may just be bad, but this is not a fatal injury to a computer.
Replacing the Keyboard and Mouse with a standard USB keyboard and mouse, should resolve all of your issues.
PS2 is an older technology that keyboards and mice used to run on; Now however USB connections are used.
Further more, if this an HP Desktop with 2 USB ports on the front, and 4 USB ports on the back, you will want to avoid using the 2 USB ports on the front, especially on older HP and Dell Desktops, the reason is the power supplies often do not have enough power to run multiple USB devices on the front USB ports.
The back ports should be fine regardless of the number of devices.
Hope this helps.
Dec 10, 2013 | Computers & Internet
Set up netgear xeb1004 ethernet switch to network printer hp lj 4050n and printer will not work despite everything functioning properly otherwise...help?
double check and double check again just to make sure you have everything connected properly. go to the start menu and select my computer. it may be in my network places. if you dont see it its not connected properly.
Jan 24, 2011 | NetGear (XEB1004-100NAS) 4-Port Ethernet...
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
Apr 05, 2017 | SMC Model EN104TP 4 PORT 10 BASE-T...
Unable to have internet connection with my desktop that is connected to HomePortal (1800HG) by USB but my laptop can connect to internet that is attached to Local Ethernet Connection port; the three green...
Oh my ... This is a question where I dont have to ask for more information.
Pleae connect your desktop to the router using a Cat 5 ethernet cable. I'm not a fan of USB connection for networks ... Ethernet works so much better. Do this even if you have to add a NIC to your computer.
You may find some benefit from using Network Magic, free to download and evaluate. You may like it as much as I do and pay for full extended use NM can perform all your network administrator duties. (I have 5 interconnected networks in my house that connect more than 20 computers)
Thanks for using FixYa.com
Positive comments always welcome
a
Oct 28, 2009 | 2wire HomePortal 1800HG Router...
It won't assign an IP number why
It isn't a router, and so never will, as it can't... It has no idea!
This is what you have: http://en.wikipedia.org/wiki/Network_switch
This is what you need to get assigned a Private IP address thus creating a home network. http://en.wikipedia.org/wiki/Residential_gateway
Enjoy.
Oct 12, 2009 | Dynex 4-Port 10 Mbps Ethernet Hub
I re-imaged the unit & it says the network card is working properly in device mgr. But it wont go online when i connect a cable. It stays on "Network Cable Unplugged". The LED on the connection on the...
1. Try different cable if possible.
2. Check the network port of the laptop. Make sure the pins are in tact and there is no dust/dirt or anything blocking the port.
3. Verify the other end as well. Check the hub/modem/switch or whatever you are plugging into. Make sure it's securely plugged in.
4. If plugging into a router, make sure you aren't plugged into the Uplink or Modem port. If it's a simple 4 port hub, avoid plugging into the uplink port as well.
5. If you have a cable modem that plugs into a router then into your computer, test by powering everything down. Plug the laptop directly into modem's ethernet port. Turn power on to modem. Turn power on to laptop. Check your network light and test internet. If it works there's something wrong with router. If it doesn't, look to the cable for issues.
6. Lastly, if none of those steps worked, remove the ethernet driver and reboot laptop. Let Windows detect the ethernet card, then re-install the driver choosing to overwrite the existing. Know that Windows will tell you you're device is ok just because a driver loaded successfully. It doesn't always know if the driver is the correct one.
Sep 29, 2009 | HP Pavilion N5415 Notebook
Says ethernet adapter not plugged in
I always try to do the obvius first but sometimes overlook this point. Try changing your cable. I've run into this with my usb cables all the time. Hope this helps.
Feb 21, 2008 | 2wire HomePortal 1800HG Router...
Can a 1800HG gateway in my garage/workshop link *wirelessly* to my 2wire 2700 HG-B wifi AP internet in the house?
try going onto http://192.168.1.254/xslt?PAGE=J30&THISPAGE=J29&NEXTPAGE=J30 on the computer connected to the 1800hg and set the router onto bridge mode (deselect enable routing). You might be able to set the two routers to connect then from here: http://192.168.1.254/xslt?PAGE=J09&THISPAGE=J30&NEXTPAGE=J09 or somewhere else in the MDC, not sure if it will work as I haven't tried it, but I hope it helps.
Feb 19, 2008 | 2wire 1800HG Router (RG1800HG00)
Wireless yes, but ethernet no, why?????
There are two separate IP configurations for the wireless and wired ethernet adapter it could be that the two adapters may be configured differently -- the wired one incorrectly for your home.
It could be a bad ethernet cable.
It could be a bad port on the router.
It could be a hardware problem with the wired network adapter.
Dec 20, 2007 | 2wire HomePortal 1800HG Router...
2wire 1800HG Router (RG1800HG00) Logo
405 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
