Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Resetting password i have lost my admin. password is there a way to resett it to factory settings?
    Scholar:
  • 193 Answers
Go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
Posted on Nov 15, 2007
How do i delete a bt broadband account,??
Here is how to reset your Linksys wireless router to the factory default settings in order to clear any existing properties.
  • Note: All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router user name and password will revert to the default of admin as the user name and no password.
To reset your Linksys BEFW11S4 router to the factory default settings:
  1. Hold the reset button on the back panel of the Linksys router for 30 seconds. All your settings will be lost including WEP encryption information, MAC Address filtering information, and any SSID information you have entered. The router password will revert to the default of Admin and all user name information will be removed.
flioqsktle4l2on3s2rwrurpaery4ednch7fnrcft2qykek7dl9puwp12tebm2epxiv1cic0cgjbtccmwjiymzmxbli0zgzkwq5ytgrmzmeowlrkzmtdjf24rlu2laabtaaaaaelftksuqmcc
  1. When you access the router utility to change the router settings from the default values, be sure to leave the User name field blank and enter admin in the Password field.
Aug 18, 2014 | Linksys Wireless-G Broadband Router
I ofrget my router password
MOST, if not all, cisco routers have a small recessed button to reset the router to Factory defaults. If you've lost your password, you can hold that button for 30 seconds to reset ALL router settings to factory default. MOST Cisco/Linksys routers use admin/admin for the factory default id/password.
Jul 07, 2014 | Computers & Internet
I lost ma admin password and i wouldn't want reset my router. Is there a solution ?
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
also if its linked directly to your internet contract you could ring your ISP internet service provider and get the password from them hope this helps
Feb 07, 2011 | Trendware TEW-452BRP Wireless Router...
Lost password to router
or
hope this helps
Feb 01, 2011 | Belkin F5D72344 Wireless G Router 54Mbps...
I forgot my Password for NETGear WGT624 Please help
or
hope this helps
Jan 17, 2011 | NetGear WGT624 Wireless Router
Lost password
•Connect the power cord
•Unplug ALL Ethernet connections
•Hold down the reset button for at least 15 seconds
This will reset your router to factory defaults. •Open Internet Explorer (with the computer connected to the Router)•Enter 192.168.1.1 into the Address Bar, push Enter•If 192.168.1.1 does not appear to work, try 192.168.0.1•Under the Username field enter "admin"•Under the password field enter "password"•Click "OK"
Good luck and thank you for using FixYa! We would sure appreciate a 4 "thumbs-up" rating for this FREE answer. Happy holidays!
Dec 05, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
I lost the username and password for Linksys WRT54G2 Wireless Router ,,how can i get them back?
Just reset your router and use (admin) for user name and password. To reset your router you can see a small hole in your router which is labeled reset. Use a pin and insert it to the hole and push.
Jun 09, 2010 | Linksys WRT54G2 Wireless Router
Lost my admin password
Do a hard reset. On most typical routers you hold down the tiny reset button with a paperclip for a few seconds until all the lights shut off, and quickly release it (5-15 seconds depending on model usually).
Then it will be reset to factory defaults, and you must go set up everything again. By default the password is usually (not always) 'admin'
Apr 19, 2010 | Belkin (F5D7230-4) Router (587009)
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Lost password for wireless connection
Reset your router using the reset button. That will put everything back to factory settings.
Dec 25, 2007 | Broadcom BCM5705 Network Adapter
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
977 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
