Question about Jenn-Air JMV8208A Microwave Oven
HOW TO REPLACE BLOWN FUSE
My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model is Jenn-AIR JMV8208BAS
    Brigadier General:
  • 4,088 Answers
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
2 Suggested Answers
wpcustomer
  • 408 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My JENN-AIR Microwave Oven stop
    Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
    NAR_JennAir_CustomerExperience@JennAir.com
    and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
    Posted on Oct 27, 2010
    I have a old jenn air wall oven and a old jenn air microwave mounted on top. it was a countertop model. when i removed it it was plugged into the top of the oven. would that be a 110 appliance outlet?
    The Jenn Air microwave that is mounted above the oven in your unit is 110v 60Hz. The socket in the upper rear right corner of the oven is a 110v 6Hz socket and is where the microwave would be plugged in. If you are going to replace the microwave, you can plug it into that socket. If you would rather not use that socket, you will have to drill a hole in the side of the cabinet holding the over/microwave to get the power cord out.
    Sep 29, 2014 | Jenn-Air Microwave Ovens
    Jenn-air combo micro and oven
    need to open the unit up and look for a fuse to be blown..
    Jan 08, 2014 | Microwave Ovens
    Jennair combo micro wall oven 30" replace microwave?
    When a microwave is dead, the most common causes are a blown fuse, or a blown thermostat / thermal cutout / TCO on the magnetron or on top of the oven cavity.
    You can find helpful exploded view diagrams and order parts by entering your full model number here.
    Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
    If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
    You can download Jenn-Air (Whirlpool) owner's manuals and installation instructions here.
    Dec 25, 2012 | Jenn-Air JMC8130DD Microwave Oven
    No power, it is like a fuse is blown. Outlet is fine. Where is the fuse? Not sure what else it could be?
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Dec 26, 2010 | Jenn-Air JMV8208A Microwave Oven
    My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
    Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
    No power in the microwave. It is as if you unplugged it. Is there an internal fuse in the unit? There is power to the unit. The unit shows nothing on the panel and when you open the door, no light comes...
    If you look at the back of the oven there are usually small fuses or breakers back there. Check to see if that is the issue. Also if you haven't already make sure the wall outlet is functional.
    Dec 14, 2009 | Jenn-Air JMC7000 Microwave Oven
    No power on Jenn-Air JMC 7000 ADB Microwave
    I have a different Jenn-Air built in microwave & oven combination but I'm sure my solution will work for you as well.
    My microwave was plugged into an outlet located on the top of the oven. This outlet has a "circuit breaker" that tripped while we were using the self cleaning feature on the oven. You just need to reset the breaker button right next to the wall oven outlet. Why it tripped is a mystery since the microwave was not in use at the time. Bad design.
    Of course, getting to the reset button is your only challenge. You need to pull the microwave and oven out of the wall/cabinetry in order to get to it. The unit is heavy so you will need help. Or, call a certified repairman and they should be able to do this for you in 30 minutes or less so the service call should not run you more than @$85 if it is no longer under warranty.
    I would also suggest you contact Jenn-Air to complain about this issue and seek reimbursement from them if necessary.
    Dec 18, 2007 | Jenn-Air JMC7000 Microwave Oven
    Jenn-air microwave JMC 7000 ADB has no power
    Dec 17, 2007 | Jenn-Air JMC7000 Microwave Oven
    Oven and microwave combo
    Fuses and circuit breakers imediately come to mind as the first things to check.
    Oct 28, 2006 | Jenn-Air JMC8130DD Microwave Oven
    Jenn-Air JMV8208A  Microwave Oven Logo
    1,440 people viewed this question
    Top Jenn-Air Microwave Ovens Experts
    William Miller
    William Miller
    Steve Allison
    Steve Allison
    Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
