Question about HP OfficeJet 6600 All-in-One
The print head appears to be missing, not detected or incorrectly installed
  • HP Master
  • 5,631 Answers
One or both of your printer heads is probably damaged.
Remove first black then color to pinpoint which one is and replace it with a new one.
Posted on Jul 18, 2015
SOURCE:
Failed printhead
Check as the error message suggests.
Apr 27, 2018 | The Office Equipment & Supplies
The printer won't start up after inserting new HP cartridges. It says the print head is misinstalled,
Guess your prineter is defective. If you don't know how to repait it, you should take it to anauthorized HP service
Aug 10, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Printer head appears to be missing not detected or incorrectly installed
Jul 18, 2015 | HP OfficeJet 6600 All-in-One
When I try to print this message appears "The printhead appears to be missing, not detected, incorrectly installed or incompatible.
Probably your printhead is damaged end your printer won'r recognize it. Sorry, your only solution is to buy a new one
Feb 10, 2015 | HP Hewlett-Packard - CB863AB1 Officejet...
Printing error message The printhead appears to be missing, not detected, incorrectly installed or incompatible.
Here is how I would approach this.
1. Open the cover and look at the print head. Are the cartridges installed properly and locked into place? You may wish to re-install them to make sure.
2.Inspect the print head to see if any cables appear to be pulled away or damaged.
3. Unplug the printer, and let it sit for about 30 seconds, and then apply power and turn it on. Let it run through it's initialization and then see if it provides any error codes. You may also wish to try printing a test page to generate an error code.
Good Luck,
Feb 10, 2015 | HP CB863AB1H Officejet 6100 H611A Inkjet...
Hi, (MX850) My blue ink has stopped printing. I
Performing Maintenance:
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
Step 1
Printing the Nozzle Check Pattern.
If lines are missing or if white streaks appear
Step 2
Print Head Cleaning.
If the problem is not resolved after performing Print Head Cleaning twice
After cleaning the Print Head, print and examine the nozzle check pattern (Step 1) again.
Step 3
Print Head Deep Cleaning.
If Print Head Deep Cleaning does not resolve the problem, turn off the machine and perform another Print Head Deep Cleaning after 24 hours. If the problem is still not resolved and if you are sure that the ink didn't run out, then the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
All the best.
Mar 11, 2010 | Canon PIXMA MX850 Multifunction Printer
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Printer 4355show in message
may i know if the INK that you are using is a HP genuine ink cartridge??if it does clean the copper contacts on the printer and try to check also if the ink cartridge that you are trying to insert is the compatible ink cartrdiges of the PRINTER
Sep 03, 2008 | HP Officejet 4355 All-In-One InkJet...
Can't install lexmark x4530...get spooler subsystem app has encountered a problem,etc.
Print Cartridge(s) Missing
The following print cartridges appear to be missing, not detected, or incorrectly installed:
Cartridge on Right
Cartridge on Left
May 21, 2008 | Office Equipment & Supplies
Open Questions:
See all HP OfficeJet 6600 All-in-One Questions
HP OfficeJet 6600 All-in-One Logo
761 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
