Question about Saeco VIA Venezia
Water pump Saeco Via Venezia
The pump works randomly. when it in not pumping it make too much noise. the all of a sudden it starts??????? need new pump or just good old service.
  • Anonymous Nov 18, 2007
    will not draw the water through
  • Saeco Expert
  • 223 Answers
Posted on Nov 23, 2007
Venezia vae know boil water for coffee coming out the head
It sounds like you need the tune up kit. I got mine at Seattle Coffee Gear. It was really easy to unscrew and replace the parts. Good luck
May 12, 2014 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
Not pumping waer but making hella noise
Needs to be primed. If you open the steam knob and and you don't get water out, the pump has lost its prime. Check that you hose is in the tank, or has become disconnected inside.
Jun 20, 2009 | Saeco VIA Venezia
Saeco Via Venezia leaks water from front top overhang.
That is not normal, this tells me that the pump has too much pressure that it is forcing water through the brew unit, or the expansion valve(if your model has one was not set properly). Is there a high pitch noise when the pump is running. If yes then it is the expansion, if no then the springs and the valve pins in the brew valve(small white plastic piece behind the brew unit) needs to be replaced.
May 22, 2009 | Saeco VIA Venezia
Water won't come through my Saeco via venezia coffee machine. It was working fine until I cleaned it so I don't think the pump has gone.
If the pump vibrates when trying to draw water then that is a good sign. Remo;ve the hose on the output side of the pump and turn it on to see if it draws water(BE Careful water and electricity love each other too much), it water flows out the output side, reconnect to boiler and test. If that did not solve the no draw problem then the machine is blocked either at the boiler.
May 11, 2009 | Saeco VIA Venezia
Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
Apr 19, 2009 | Saeco VIA Venezia
Via Venezia- pump is very loud
Sometimes the water filter vibrates against the water tank and it sounds as if the pump is really loud and malfunctioning. It isn't. Just pull the water tank forward and play around with the water filter and hose and you will be able to isolate the problem. You could cut the hose slightly shorter to stop the "rattling". good luck.
Jan 05, 2009 | Saeco VIA Venezia
Pump sounds loud and slurpy but doesn't pump
Try descaling the machine. Saeco has a suitable solution, although the user manual says 'you may use any commercially available non-toxic descaling agent.' The instructions are set out in the user manual, and are usually on the descaling agent label. It is important to descale regularly, at least every 4-6 months.
Mar 18, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
465 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
