Question about Sharp Office Equipment & Supplies
Screen shows an arrow and a zero ---and is stuck there. Tanx
  • 211 Answers
See do some button has been stuck inside the calculator if it is stuck you should take it out by move in it because if some button is pressed you cannot push no other buttons
Posted on Jul 12, 2009
Am a new user of netflix and stuck in a screen from last show I watched how I do get back to list of movies and shows?
in the upper left hand corner, there is an arrow pointing to the left... that would be your "Back" button. Click that arrow and it should take you to the previous menu. I have highlighted the arrow with a red square... that will not appear on your screen.
Feb 03, 2018 | Computers & Internet
Why will my bathroom scales, Model TH 321 not show weight, but only zeros?-
SOURCE:Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Jan 02, 2018 | Health & Beauty
My home screen will not boot up
You can try a Hard reset...
  • Turn the phone off, either by holding down the power and selecting turn off, or pulling the battery out and then putting it back in.
  • Hold down the Volume UP, Menu, and Power keys until the android recovery screen shows up, then release them.
  • Use Volume Down to scroll to wipe data/factory reset, then select it using the Back Arrow Key.
  • Scroll down to YES, then select it again using the Back Arrow Key.
  • The phone should reset and return to the android recovery screen.
  • Use the Back Arrow key to select reboot system now.
  • The phone will reboot to the initial welcome screen.
Sep 04, 2012 | ZTE At&t Avail Z990 Touchscreen Android...
Tanx+coty/tanx coty
I going to use the following trig identies:
cotx = 1/tanx, and tanx = 1/cotx
Therefore:
(tanx+coty)/(tanx*coty) = (tanx + 1/tany)/(tanx/tany)
multiplying the top and bottom by tany yields:
(tany*tanx + 1) / tanx
This reduces to:
tany + 1/tanx
Which equals to:
tany + cotx
Feb 18, 2011 | SoftMath Algebrator - Algebra Homework...
How do you find the zeros of a function on a TInspire
Turn calculator. Use arrow to highlight the 2:Graph and Geometry application. Enter your function at the bottom of the screen. Use TAB to move focus on command line.
Press [ENTER] to graph.
While graph is drawn, press [menu] key. Select [5:Trace][1:Graph Trace] . An X appears on the graph screen. Use arrow to move cursor towards one of the zeros you see. At some point the calculator will pop up the label [zero]
Press [ENTER]
Use arrows to move the cursor near a second zero. When [zero] pop up text appears, press [ENTER]
The value of the secon zero is also displayed.
You can also the nSolve command
Use the nSolve( function available in main calculator application. Here some exemples of syntax
On the second command line, the small vertical segment after the right parenthesis is accessed by the key sequence [CTRL] [infinity, beta, degree] key, the one under [left arrow/clear].
Hope it helps.
Oct 26, 2009 | Texas Instruments TI-Nspire Graphic...
Graphs
Once you have drawn a function (not an equation) you press [2nd][F5] to access the (G-Solv) application. The screen shows you several soft menus
  1. Root
  2. Max
  3. Min
  4. Y-ICPT
  5. ISCT
  6. Y-Cal
  7. X-Cal
  8. Integral
The one you want is Root. Select it and the application will look for the zero.t. If there are more than one roots use the left or right arrows to jump from one to the other.
Hope it helps.
Thanks for using FixYa
Oct 26, 2009 | Casio FX-9750GPlus Calculator
Memory full
need to restore your phone to its factory settings. open menu then select settings then select restore factory settings. if it ask code then type 0000(4 zeros). tanx
Jul 30, 2009 | Motorola Mobility W230 Phone US with...
Philips 3258
1. With the remote control, turn on the player. Keep the tray closed.
2. Press SETUP and use the buttons LEFT or RIGHT (arrows) to go to the Preferences Page.
3. Type 138931 and a screen will appear on TV.
4. Use the buttons UP/DOWN (arrows) to change the region code to 0 (zero), then press OK.
5. Turn off the player and turn on again.
OR
open lid; slowly press 9,9,9,9, then 0. will show region 0 on screen for maybe 2 seconds , shut lid & you are done!
One of these 2 should work. If one does post back which one please.
Sep 08, 2008 | Televison & Video
Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Feb 15, 2008 | Sharp XV-Z2000 Multimedia Projector
173 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
