Question about Thetford Norcold DE0051 Refrigerator
My Norcold RV refrigator will flash 5 times every 3 seconds and will not start
Circuit board may need to be reset.
Posted on Aug 19, 2009
    New Friend:
  • 10 Answers
No Co code board needs to be reset a a qualified tech needs to diagnose why the board set off the code. No Co means no cooling detected by Control module. This is usually cause by a ventilation issue or any number of Conditions. Reseting the board and sending g you on your way will get you running but problem is NOT fixed.
Posted on Aug 30, 2014
The burner on my 8682 Norcold RV refrigerator will not stay lit.
I take it this is a refrigerator that operates on elec as well as gas, and if so then check the thermocoupling on the unit. If it runs on elec then that is about all that can go wrong.
Oct 08, 2017 | Heating & Cooling
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
Free download norcold n611 rv refrigerator manual
DOWNLOADS
Parts List-06-08-12Reference6/13/2012669.77 Owner's Instructions - Cooling Unit InstructionsTechnical7/12/200728.17 Installation Manual - 3/23/06 - 2/19/07User Manual7/12/2007872.04 Installation Manual - 8/2/04 - 3/23/06User Manual7/12/2007791.81 Installation Manual - CurrentUser Manual6/16/20091,239.84 Installation Manual - Through 8/2/04User Manual7/12/2007508.79 Owner's Manual - 3/23/06 - 2/19/07User Manual7/12/2007370.63 Owner's Manual - CurrentUser Manual1/20/2010630.82 Owner's Manual - Through 3/23/06User Manual7/12/2007394.09
I believe you can find the fault codes above. Here is a link to the Norcold N611 Information and Contact Page
Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
My Norcold N611 frig code flashes 3 time every few second and doesn't go into A/C mode and will only go into gas mode when the switch is in auto mode and the interior light stays on even when the
The N611 will flash 3 times as an AC heater fault. If your AC heaters are ohming out properly (48 ohms of resistance), then you have a bad power board. If the AC heaters are not showing around 48 ohms of resistance, replace the AC heater. It's going to be one of the two. Here is an article on it:
Norcold Fault Codes AC HE or On light flashing 3 times What to do
Aug 16, 2012 | Refrigerators
Norcold fridge does not stay cold.we turn it to lp gas or electric and it goes to an n.
Quit playing with it ... absorption refrigs work slow ... and do not recover well ... If yours has a thermostat ... set it a little lower ... check it in the morning ... use a thermometer inside. Keep track of the temps.
Putting warm food in the frig will result in a big slowdown in recovery.
Thanks frr using FixYa.com
Oct 05, 2010 | Thetford RV Refrigerator - N300 Model -...
Norcold refrigerator igniter not generating a spark. I can light the flame with a lighter, but once refrigerator reaches desired temperature flame goes out and when more cooling is needed a spark is not...
Sounds like your ignition board is not working.
Aftermarket ones have a common automotive fuse.
Have a look at the following on line so you know what you are looking at in your unit.
Dinosaur electronice makes a UIB ( universal ignition board ) that will fit just about any fridge.
about $100 online. $250 where I tried to buy one at a rv place.
Apr 05, 2010 | Thetford Norcold RV Cooler/Freezer
RV model norcold n811rt not cooling
I have a norcold fridge model #N811RT and the flash code blinks 5 times then stops then repeats. both fridge and freezer are not cold were are currently living in are 5th wheel and it was currently -30c for 3 days any help would be of assistence.
Colin
Aug 03, 2009 | Migali Refrigerators
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Norcold RV Refridgerator N611
Go to www.bryantrv.com and go to "service documents" and download the manual for your model "Norcold N Series". It says that 5 blinks then a pause means "no cooling detected by controls" see page 21 & 37.
Jul 08, 2008 | Refrigerators
Thetford Norcold DE0051 Refrigerator Logo
1,298 people viewed this question
Top Thetford Refrigerators Experts
Sheldon Dedek
john h
Steve Allison
Steve Allison
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
