Grill does not work but oven does, any ideas!
This sounds like the grill element has blown, usually when an element blows it will take out the circuit breakker or RCD at the consumer unit.
If you check around the grill element you will probably find a very small hole in the side of the element, this doesn't happen every time but most.
These are usually quite easy to change but remember to turn off the power before doing anything on the cooker.
You should be able to order the part off the internet, lots of companies supply these parts. You will need your model number and obviously your credit card.
If you don't feel confident, I am sure a local electrician will help you. I would advise that you don't use a company that specialises in appliance repairs as they will charge you a fee just to come out to see you.
Hope this helps
