Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Driver and drive recognized, but not available on desktop
When asked to populate volumes: status shows "not initialized". How do I initialize (format?) this drive?
  • 121 Answers
Right click my computer
click on manage
go to storage >> disk management
you will see your disk drive their
you can format or repartition it easily by right clicking on it
there will be options for partitioning and formatting the drive
Posted on Jul 12, 2009
Restore Volume on Toshiba HDD2F22 ?
From what i understood is. you've cleaned HDD, and Recreated partitions. or if not recreated partition and then too it showed as partition as before then Hard Drive having issue and showing ghost partitions and which can not be accessed.
Jul 01, 2014 | Toshiba HDD2F22 MK5061GSYN Hard Drive...
My SSD (ata ts256gssd720) is not recognized when I try to install win7, I had ubuntu earlier (only ubuntu from the beginning)
When you say "not recognized", do you mean that the drive does not show up under "My Computer" with a drive letter? Or that the OS does not even know the drive is there? It is possible that the SSD was formatted using an Ubuntu-specific file system that Windows does not recogize. In this case, the drive may be seen as "Not Activated". To check this in WIN 7, click on START, then right-click on COMPUTER and select MANAGE. When the Computer Management window appears, under STORAGE, select DISK MANAGEMENT. Wait for the window to populate, then scroll down looking for the SSD in the list. It should list a disk number, size, and status of the drive. If it is not ONLINE, then there is a problem. You will probably have to initialize it, partition it, and format it to have WIN 7 see it. Be advised however, that this will remove all data previously stored on it.
Oct 30, 2013 | Transcend Computers & Internet
Just bough this hard drive, and when I plugged it in, drivers were installed but it was not recognized by the computer. Tried to initialize it through disk management (windows), but got a cyclic redundancy...
If you just bought this drive, I would suggest to return it to the store and ask for a replacement. Don't forget to bring in your receipt of the store, when you bought it.
Oct 14, 2013 | Seagate STCA4000100 - 4TB Backup Plus...
Installed a WD Caviar Green SATA internal hard drive in my Gateway PC. The bios doesn't show it, the device mangler doesn't show it. I disable the antivirus software & the UAC as suggested by the many...
New HDD Not Recognized by Computer
This occurs when the HDD is not “Initialized” by the disc management system in Windows. If you do not have software that came with HDD or the HDD is a secondary drive for backup and is not to be used as an initial boot device, then when you installed the drive it did not go through the necessary steps or Windows simply failed to do it’s job. In this case, connect the drive as you normally would, go to the control panel > Administrative Tools > Computer Management > Look in the left Pane, scroll down and click on Disk Management.
Your drives will be listed here, even if they are not initialized. Look below the top pane and find the disk that is listed without a drive letter. If you look at where the drive is named, it will also say “offline”. Right click in this area that says “offline” and click on “Initialize”. The system will ask a few questions, just click ok to what it asks, this will initialize the disk and you can then partition the new drive to how you want it set up.
Jan 18, 2010 | Computers & Internet
Say's it needs to initialize and comes up with eisa.
The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
EISA Partition Delete
1. Open a command prompt as administrator.
2. Run Diskpart application by typing Diskpart in the command prompt.
3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
4. Then type in list disk and press Enter key to show all hard disk drive available.
5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
select disk 0
Finish by Enter key.
6. Type list partition and press Enter key to show all available and created partition in the disk selected.
7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
select partition x
where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
8. Finally, type in delete partition override and press Enter key.
Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
Nov 19, 2009 | Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
My 1TB Hard drive media player has stopped working with my laptop, it's status in not intialized and when I select initialize it comes up with a message saying driver is not ready! Some really important...
you need to go to disk management and re initialize the drive. disk management is in the control panel and then administrative tools look in thet for disk management and see if it is showing up.
Oct 19, 2009 | Computers & Internet
1TB myBook makes recognition sound but isn't recognized
From your description, this clearly indicates a problem with the physical media inside the unit. Your only real option is to see if the store will replace it (so you can have it immediately) or to go through WD Warranty Servicer (which is awesome, but takes about a week). Since you've had it less than 30 days, most stores will do an immediate replacement if they have it in stock.
Mar 21, 2009 | Western Digital My Book Essential 1TB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
I have a Onetouch Mini 4, operating fine on two computers with Windows XP but couldn't get it working on Windows 7. I plugged it in and it would be recognized but a message would come up saying there were errors and to scan. Tried scanning and not scanning and couldn't get the drive to work. If I tried to open it would give me the "access denied". I couldn't get to a security tab from a folder as none of them were working.
It ended up that I wasn't listed as an owner nor had any permissions so I needed to be added to the device.
Here is what I did -
System, device manager, disk drives, right click on onetouch, properties, volumes, populate, the select on touch volume, properties, security, advanced, change permissions, add, typed in my user name - hit checked names (it fixed the format), then hit ok.
Then make sure you set the permissions for all the users.
Sep 08, 2008 | Computers & Internet
SanDisk Initializing
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 03, 2008 | SanDisk Sansa m230 MP3 Player
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
254 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
