Question about Bose Lifestyle 48 System
I have a Bose RC-9 remote which works only very occassionally. The batteries are new (each around 1.7v) > It seems like the pads under the remote keys are not functioning properly Can I fix this ? or do i have to buy a new remote> Will a "contact" cleaner spray work ?
2 Suggested Answers
SOURCE: How do you pry apart a Bose RC-9 Remote control
There are 3 tabs on each side, and 1 on each end. Pry with a thin flat head screwdriver, but be gentle as you can break these easily. The first tabs are 2 and 5/8 inches from the top end of the remote, with the others 2 inches away from this. The ones on the ends are dead center.
Posted on Nov 09, 2010
How to reprogram the remote control rc 18t1-40
If replacement batteries were installed correctly and the remote still doesn't work, you may have to replace it.
May 24, 2015 | Bose Lifestyle 28 System
Roku 1 not working with remote
Check the condition of the battery in the remote. If no good, replace.
Reboot the Roku by disconnecting from power supply, wait a few seconds and re plug unit. Should work then since I have had my Roku lock up like this on 2 occasions.
If neither solution does the trick you just hope unit is still under warranty.
Mar 12, 2015 | BoseĀ® CORPORATION Bose - RC-PWS II...
How to check my bose rc-9 remote whether its working or not?
Put batteries in it and point it at the electronics unit and press some buttons
Dec 27, 2014 | Bose New Original RC9 Remote Control
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
Remote rc25 not working
Check its infrared emission first. As it is new, the only possibility is with the failure of infrared LED inside it. If you wish to get more details about how to check a remote control, check this link, and pull up older posts there.
Feb 24, 2013 | Bose RC-18S Remote Control
Bose remote RC-25 won't work anymore
Check the remote control for its infrared emission. Check it with fresh batteries. Check it battery contacts, inside its battery compartment for any rust or dust accumulated, which prevents the electrical contacts. If all are found OK, you remote control need cleaning. To clean it, you have to open it. If you wish to know more details about how to clean and check a remote control, check this link.
Feb 17, 2013 | Bose RC-25A Remote Control for Lifestyle...
Rc-9 remote only works if within 2 feet of bose lifestyle 12
Replace its infrared emission LED. It is weak, and so the signal out from the remote control too.
Nov 18, 2012 | Bose RC-18S Remote Control
How can i get my bose rc-38t1-27 to work. i have
the electric cord id also an antenna. do not let the elctric cords touch other electric cords or it wil have interference.
Apr 14, 2010 | Bose RC-18S Remote Control
Can't get new universal remote to work with bose av28
How old is your remote? My bose remote was prone to breaking. The RF antenna inside the remote housing tends to break away from the electronics board. I have re-soldered mine on a number of occasions. This is not a complex fix for someone who can use a soldering iron. After it happened the third time, I installed padding around the antenna so that it couldn't shake around and break free. That seems to be working so far. Hope this helps.
Dec 10, 2009 | Bose Lifestyle 28 System
I need a replacement remote control - Bose RC9
I have same problem with RC-9 working intermittently with some light banging. Thanks for the tip above. I tried opening the remote but the case wont open. Is there an easy way? Dont want to break the case while opening. Thanks.
Apr 07, 2009 | Televison & Video
Bose Lifestyle 48 System Logo
321 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
