Question about Jack Lalanne Power Juicer (Stainless Steel)
It will not turn on, i tried the reset button still no power. How do i fix it?
    Brigadier General:
  • 4,088 Answers
Check the plug end of the power cord--if the cord is pulled instead of the plug, it can cause breakage of the wires inside the cord. Try pulling the plug from the cord--if the insulation seems to stretch-out, shorten the cord a little(an inch or so) and install a new replacement plug. If cord seems ok, then an internal inspection of the motor area is the next option.
Posted on Jul 12, 2009
Omega 8003 does not turn on. Could it be the switch that is defective?
Never oil a power switch. Sounds like a defective switch and if others have the same problem go to the manufacturer website and look for a possible recall or solution.
May 18, 2014 | Omega Juicers
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
Hi- I wanted to use my juicer again after not having used it in at least 2 yrs. Last time (which I can't remember!) I used it, it worked. This time, all loaded up with veggies, when I turned it on it...
Just looked at mine because I thought there also might be an interlock switch
where the latch arms snap shut. There isn't one, at least on this one. Yours
might be a newer edition, so make sure the latch arms are fully seated and
snapped closed. You can also call Omega at 1 800 633 3401 and run it by
them. The reset switch should be in the pushed in position, it will pop out if
it's tripped.
Apr 29, 2011 | Omega 1000 Juice Extractor
Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
Jan 09, 2011 | Waring Juicers
I am not able to turn my Acme Juicerator on.
Try the reset button on the bottom of the juicer.
Dec 23, 2010 | Acme 5001 Supreme Juicerator Juice...
Motor failure
First, turn off the power at the circuit breaker and look for a small reset button. There should be one. If not, leave the juicer on off - and turn the circuit brkr. back on, and try again. If this still doesn't work. Check and see if you're plugged into a GFI receptacle, which has a little reset button on it. In fact, you can check this first. Good Luck to you! Feel free to contact me again if this doesn't work for you. - Jim
Mar 29, 2010 | Breville BJE200XL 700 Watts Juicer
AMCE JUICER WON'T WORK
4 SCREWS HOLD THE BASE PLATE.
REMOVE IT AND HAVE A LOOK. THE
WIRING IS PRETTY SIMPLE. THIS THING
IS REALLY BUILT, SO IT MIGHT BE SIMPLE
LIKE YOU SAID. MINE IS 19 YEARS OLD
AND I HAVE PARTS FOR ANOTHER 19.
May 19, 2009 | Acme 6001 Juice Extractor
Juicer will not run
Make sure the stainless bar running across the top is snug on the left and right groove. It has a shut off switch when not installed properly.
Jan 08, 2009 | Jack Lalanne Power Juicer (Stainless...
Overtemp switch keep tripping
REMOVE BOTTOM AND TRY ADJUSTING
RESET BUTTON BY TWEAKING SMALL
SCREW ON BUTTON HOUSING. TURN
EITHER WAY TILL YOU HAVE LONGER
RUN TIME.
Sep 04, 2007 | Omega 9000 Juice Extractor
Jack Lalanne Power Juicer (Stainless Steel) Logo
173 people viewed this question
Top Jack Lalanne Juicers Experts
Cory Koby
Cory Koby
Roger Paull III
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
