Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
Dingo by manco
Where is the spring at on the Briggs and Strattion 5hp i have no clue where it is
Most likely the spring you are looking for is located on the torque converter. if you remove the plastic housing, the lower disc that is attached to the engine by the belt (not the chain) there should be a spring on the outside of it. hope this helped.
Posted on Jul 30, 2009
    President:
  • 3,433 Answers
The spring goes from the throttle to the tin paddle. I believe its the governor
Posted on Jul 11, 2009
Briggs & strattion ignition wire diagram
Check out Google and you should be able to down load a PDF Manual that will show you every thing you need to know.
Oct 02, 2012 | Briggs & Stratton Briggs Stratton Intek V...
How to rebuild a 17hp briggs & strattion motor
Get the date code and model off the rewind cover, Jacks small engines sells kits complete along with others. If you are a hobbyist go for it but in the long run is it a greater value to purchase a short block instead.
Sep 23, 2012 | Garden
17.5 hp Briggs & Strattion has no spark
unplug the harness to the engine should be a 5-6 wire give or take then crank it look for spark if you get spark that way check the safety switches if no spark change the coil
Apr 24, 2012 | Briggs & Stratton Briggs Stratton...
Govenor spring correct fitting 375 sprint
hello, If you go to briggs and strattion.com model parts search or manual,you will need engine model number,to find your parts or engine illustration,hope this helps. @@
Feb 09, 2012 | Garden
I have a mtd 5hp. briggs@strattion engine its not getting any gas,Ihave put a new diaphram in it and it is still not getting gas, I can pour gas in the carb. and it will run untill it runs it out.
Check the screw on the bottom of the bowl, it has little orifices on it and they need to be cleared. What kind of diaphragm did you replace and where was it located????? Pouring fuel it the carb is not a solution to problems like this I do not recommend that you do that! Your problem is just a clog somewhere you have to find it, this very common problem. This is how us repairmen make good $$$ off of people in your position. This stuff is not ROCKET science! Good Luck...
Apr 18, 2011 | Garden
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
365 people viewed this question
Top Briggs & Stratton Hammering Experts
cavs1
Thomas Merrill
Thomas Merrill
Level 1 Expert
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
