Question about Skyworth SLC-1971A 19-inch 720p LCD TV/ DVD Player
How do I fix lcd tv skyworth 40E58 power problem
Done checking secondary line of the power supply and noted no 12v output but only 24v are present. asking for help finding the component that probably causing the problem.
    Top Expert:
  • Skyworth Master
  • 76,054 Answers
The command to generate the 12VDC; from the power supply should come from the main board. S the main board should be troubleshooted in this case. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Jul 18, 2015
Testimonial: "you're right but i think there's an existing command from the main board but failed to start-up after pressing the power on button, what possible that causes the problem? it is no other but the main board?"
  • michael miranda
    michael miranda Jul 22, 2015
    in addition,the standby indicator LED lights in red but when pressing the power on, it turns to yellow green then off immediately in second..is there possible short circuit at the main board or there is a faulty in the SMPS?
    i need your help sir "the night".
SOURCE:
Power but no picture
you need to check weather the power supply has complete output dc voltages 5v stand by, 5v detect 12v-16v for audio and tuner and 24v for back light. if just only an stand by voltage, the cause is either the power supply failed or the main board detect an error in the inverter board .
Jul 26, 2012 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Philips 37PF3321/10 At first the pictures were on and off but now there is no pictures. Sound remains perfect.
The problem might on on your inverter board or the back light is busted.
1.Check for the input supply of the inverter board. the supply must be 24V of 12V use a multimeter range on DC
2.Then if you have input voltage (24V or 12V), check for the output of the inverter board it should have 500VDC.
3. If the output is present , the problem might be on the back light. Replace it, its available on electronic shop.
Hope this may help you
Aug 20, 2011 | Philips 37PF7320A 37 in. HD-Ready LCD...
My lcd flat screen displays black and gray lines with no picture and sound
check your power supply use a voltage tester make sure your power supply has a 5v,12v,24v output.If no voltage is present replace the power supply.
Aug 11, 2011 | LG 42LC2D 42 in. LCD HDTV
How do I tell if my power board is out
You can check that the power supply is getting power from the power cord. then check the fuse on your power cord. Last you can check the output power of your power supply. You can get parts from www.interliquidparts.com
Jun 08, 2011 | Memorex MLT3221 32 in. LCD TV
Were can i purchase protron ac/dc power supply for protron pltv-32 pltv32 lcd tv
Check this link below:
http://www.lcdpayless.com/productpage.php?productId=5441
Specification of Protron pltv-32 lcd ac adapter:
Output Voltage: 24V and 12V Volts DC
Amperage: 6 A and 3 A Amps
May 15, 2011 | Protron Ac / Dc Power Supply For Protron...
Hello, I have an LG LCD TV Model : 37LC2RR-2L, I can get sound on th tv, the screen is on but no image appears.
You're backlight inverter is faulty.
You first need to check your power supply and ensure you have 24v output to the backlight inverter.
If you lack the 24v you will need to replace capacitors in-line to the 24v rail to get power back to your backlight inverter.
Look for these:
If your 24v is OK then you will need a replacement inverter to restore your picture to your tv.
Best of luck!
Apr 18, 2011 | LG 37LC2RR 37 in. LCD TV
Need a ac adaptor for a Protron PLTV-32. MODEL LU32A1A3. INPUT 100-240V 50-60Hz 3.0A MAX.Output +24V-6A +12V-3A
I found one through Powerpayless.com at http://www.powerpayless.com/ac-dc-power-adapter-for-protron-pltv-32-pltv32-lcd-tv.html. It works great!
Mar 01, 2011 | Protron Ac / Dc Power Supply For Protron...
I have a Bush 26" lcd tv. when i try and power the
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Can't answer more than this without any details.
Mar 27, 2017 | Televison & Video
Will not work at all
check for the power supply is locater at the back of the tv..you need to open the cover.the output power of the the power supply is 5vdc for the cpu and 12v-24dc for the backlights..visually inspect the components of the power supply.replace any burned capacitors and resistors..replace the secondary fuse with the same ratings..
May 17, 2010 | Niko SV3206 32 in. LCD Television
Skyworth SLC-1971A 19-inch 720p LCD TV/ DVD Player Logo
350 people viewed this question
Top Skyworth Televison & Video Experts
Marvin
Marvin
Are you a Skyworth Televison and Video Expert? Answer questions, earn points and help others
