Question about AOpen AX4SPE-N (91.8AT10.701) Motherboard
I unplugged the some of the wires to install a new hard drive the wires i unplugged are the power wire reset wire and i need the diagram to show me how to plug them back in right so my pc will turn on
  • 2,567 Answers
1. Go to: http://download.aopen.com.tw/Default.aspx
2. In the drop-down menu labeled "select a product", select "Motherboards".
3. In the drop-down menu labeled "select a Model", select "AX4SPE-N".
4. In the drop-down menu labeled "Category", select "Manual".
5. Download the first item on the list: "English Manual for AX4SPE-N
6. On page 22 of this manual, there is a connection diagram for the front panel connections, which you refer to in your question.
Posted on Jul 11, 2009
Tip
How to replace a hard drive.
WARNING:when you replace a hard drive, you need to re install windows.
Step 1- unplug your computer and wait at least 24 hours before going to step 2
Step 2- find and take out all screws AFTER 24 hours.
Step 3- take off the cover. this may take time
Step 4- draw a diagram of the hard drive and all wires connected to it. use color codes.
Step 5- take out all cables that are plugged into the old drive. Take out the drive.
Step 6- Put the new drive in. follow the diagram you made (you did do that part, right?) to reconnect the cables.
Step 7- put the cover back on and screw it in place.
Step 8- install windows
on Jul 19, 2010 | Computers & Internet
In Need Of Wire Connection Diagram of Jumpers, Power Source, & SATA Cables/Cords
Ron ,you write the drive,i suppose you have one drive.C\drive.if you removed C\drive and replaced it with the new drive you have to have the WINDOWS INSTALLDISC.you can't change C\drive all windows files are on it.there of BOOTFAILURE.solution put back the old drive.if you want moore space you have to buy a new disc.windows install DVD.
May 12, 2013 | HP Pavilion a1230n (EG134AA) PC Desktop
Emachine w3107 wiring diagram
Good luck on finding a wiring diagram. Usually those plugs represent the Power Button, the Hard Drive and the other sometimes represents a reset button. If you remove the cover and sit the computer on it's side, take a flashlight so you can see inside at the motherboard. If you look from where the wires come from on the front they usually stick into little prongs on the side of the motherboard. The motherboard will have little written identifiers such as hdd for the hard drive light, pwr for power or power reset, fan for fan, etc.
Also sometimes if you look on the little piece at the end of the red, white and black wires where it plugs into the motherboard prongs, sometimes it will have writing on it as to which one it is.
Mar 24, 2012 | Computers & Internet
I'm installing a new radio in my 2001 trooper and need the wiring diagram for the radio connections.
there was several different versions the connector is all the same wire colors are different main difference was African vehicles had power antenna switch. need to know which part of the world you from? ill show you the right hand drive one.
stevenhurc_8.jpgradio connector pin locations.
Feb 23, 2011 | 2001 Isuzu Trooper
Need wiring diagram for cadet the hot one heater so i can install new fan motor
You do not need a wiring diagram to replace the fan. TURN OFF POWER.
The fan will have two wires coming from it to two places. Make a little map of that location. There is usually a quick disconnect, you unplug and swap.
Nov 07, 2010 | Cadet Manufacturing Hot One® RCP502S...
Emachine t2984 - need to diagram to install power & hard drive
There is 2 main cables you have to worry about to feed power to the system. One looks like a big rectangle block with a mess of wires attached. Make sure he is hooked into the system. Then if its an newer unit you will find a plug that has square look to it with just 4 wires attached and should plug in nearby the processor. (only newer units us this) Also if your dealing with the cant turn it on issue make sure to remove all cards off the board like the NIC, Video Card, and Audio Card. I am unsure as to weather or not your system comes with everything onboard or if its stand alone cards. If you still cant power on theres a bigger issue at hand and that maybe that your motherboard has blown.
Mar 16, 2009 | E-Machines eMachines Desktop PC
I need to reset the system password on a HP NC 4010 notebook
If it is a bios password, you can reset by using the jumper which should be located near the cmos battery.
Mar 16, 2009 | HP Compaq nc4010 Notebook
Installed an Upgrated Mother Brd,in my Hp Desktop Tower,but the power Switch receptacle in the New Mother Brd has 16 pns
You need to track the wires from the case front panel to thier locations: one will be your power switch, one your reset, one hard drive activity light, and one your power light. You want to note and label which light or switch they go to then go to the new motherboards manual and plan which wires need to go where.
the front panel switches : reset and power switch- these are momentary switches so it doesnt matter which way they go.
hard drive activity and power light- these should have a colored wire and a black or white. the colored wire will be your + side.
Nov 08, 2008 | Computers & Internet
Kt6v jumper settings
Some wiring can be confusing such as with the board we were using. As you can see the wires mainly connect from left to right but the hard drive LED and the Key Lock wires connect from top to bottom but still show where the (-) connection is. This is where you need to pay close attention to where things actually connect to the motherboard as many boards have similar configurations.
May 23, 2008 | Abit : KV7 Socket A KT600 Motherboard
AOpen AX4SPE-N (91.8AT10.701) Motherboard Logo
243 people viewed this question
Top AOpen Computers & Internet Experts
Alun Cox
Jim Goldsmith
Jim Goldsmith
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
