Question about LG RH1999H DVD Recorder/HDD Recorder
Cannot write from HDD to DVD
When trying to write from the harddisk to a dvd the machine would "freeze" midway. I have tried to make chapters often but that wouldn't help.
I also shipped in my xbox 360 into microsoft and they told me that they have such a high demand for the 360 that they needed to have 3 different manufacturers handle their dvd rom drive assembly.....the rep told me that it seems to be that one of the companies who mad the dvd drives isnt up to par with the requirement of the system....so theoretically if 3 million copies of the xbox 360 were made...and 1 out of the 3 companies messed up (1/3) 1 million xbox 360's should be malfunctioning....a HUGE problem....i sent my in before the masses and then there is no telling how long it would take so my suggestion is to send it now dont wait to see "if" they could solve it some other way just spend the week or 2 with out your precious xbox to ensure its working condition because they can only fix it before your 90 day warranty runs out.....
Posted on Nov 17, 2007
Toshiba DVR620 manual chapters lost
Sadly DVD makers don't make there machines compatiable with home recorders software. I'm afraid there's nothing you can do about chapter markers in this case.
Jan 28, 2010 | Toshiba DVR620 DVD Recorder/VCR
The DVD player has problems midway thru a DVD
Hi I am Vortash there is nothing actually wrong with your machine ?.. the problem is rental dvds are not shall we say treated with reverence by many of the subscribers to video shops ?.. Disks get damaged and scratched and dvd players that are in need of cleaning on the lens of the laser especially tend to ripple at the slightest imperfection as do some with critical read settings .
I remember when the DVDs and cd first came out they where seen as indestructible RUBBISH they are as sensitive as the old vinyl record or rather the laser is .. if it has a damaged disc it has to work twice as hard trying to pick out the information when most of the time it is being deflected off the area that it is supposed to read . It is true 90% of the time they ignore some damage but 10% of the time they just can't cope .. Get a good dvd cd cleaner and while the disc is cleaning the machine you clean the Video DVD with the solution and cloth provided ... hope this helps Regards Vortash
Apr 06, 2009 | Sony SLV-D300P DVD Player/VCR
Dvd's keep freezing
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
Mar 17, 2008 | Alba DVD-108 DVD Player
Multi region hacks
Try this may be work
Multi-Region:
Put DVD into player - wait for regional code violation screen to appear
Once this has occurred press the M (Memory) button on your remote
Press 1 for Title 1 and Play on the remote - this will over-ride the regional code violation detection menu
You can watch the movie by pressing Fwd on remote and change chapters by using the T (Title/Chapter) button on the remote)
or
Switch On DVD player without disc in machine
Press Enter
Press 8, 4, 2, 6 and 9
Press Enter
Player should turn itself Off. If not switch it Off
Switch player back On
Mar 05, 2008 | Televison & Video
LG DVD/HDD recorder RH2T80 hard disc problem
I've got the new firmware. Email me @ damian.hocking@gmail.com
It'a 7MB file, just copy it and play & you should be ok.
Jan 12, 2008 | Televison & Video
XBOX Console error 07 now error 12
12 - kernel - DVD parameters (PIO/DMA)
Same as #10, only not very common.
10 - kernel - DVD timeout
Actually its almost the same as error 6/7/8. But also make sure the yellow cables are properly connected to the motherboard and the dvd drive.
1. Make sure ide cables are connected good.
2. Make sure the yellow cables are good and properly connected.
3. Still no succes? Try another dvd drive of which you are sure it is working.
6 - kernel - Cannot unlock HDD
If you understand the above, you should be able to understand what this means. It means you are trying to boot up the xbox with an harddisk that is locked in combination with ANOTHER motherboard than you are using it with right now.
What can i do about it, you ask? Well place the harddisk back in the xbox where it came from. After that, UNLOCK the harddisk with the same procedure i explained above (see error 5). Now when the harddisk is UNLOCKED, put it in the xbox which gave you the error. Now when you boot up with the chip ON it should not give you an error anymore.
However when you put the xbox on with the chip OFF your xbox will give you an error. (error 5) So to make sure you can boot original and boot with the chip ON. Next do the same as above: "Boot up your xbox with the chip on. Preferrably with a slayer evo-x cd. Now you choose "Eeprom management." Than you choose: "Lock hdd." It takes one second. After its ready it should say something like "Done"
When it is ready just turn off your xbox. Disable your chip and try to boot original. Now there should be no more error.
7 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. ALso try to reconnect the ide cable to the motherboard.
Press pretty hard so it goes all the way in. Make sure it is seated straight and proper in the drives and the motherboard. If you still have an error 7. Try another ide cable. If that won't work try another harddisk. If there is still no go, try to set the jumpers on the rearside of the harddisk drive. Set it to master or cable select.
8 - kernel - No HDD found
Please make sure your xbox hdd is attached properly. Most of the times the Ide cable came loose, or isn't seated properly in the IDE port of your harddisk. ALso make sure the power supply cables are intact and working.
Make sure the ide cable is also connected properly to the rest of the hardware (dvd and motherboard).
Dec 26, 2007 | Microsoft Xbox Console
Can't record from hdd to recordable dvd
Had the same problem on my 6month old 3440H, its the degradation of the cheap Asatech Chinese DVD drive that is the source of the problem. . My 3440H HDD to DVD transfer sequentially degraded, It stopped recording DVD+ and -R's then on RW's it sometimes performed and some not.I gave up using cheap DVD's then with higher quality disks  it would frequently report task completed but then would not plaback or freeze in the way you describe. I bought the DVDR from the CO-OP Xmas 2006. Co-op no longer support electricals so when it went wrong Co-op gave me a service centre to take it to. Long story short Philips dont recognise the service centre and they declared my warrany void. Tried to re-engage with Philips but they basically were not interested in supporting their product..
Not an elegant fix but since Phillips were useless,  I opened the box nothing ....to lose ..I now run it on a bare external Sony DVD drive using extended ribbon and power cables as its a bit tricky to find space in the box to mount the drive.
Regards
Murray
Oct 13, 2007 | Philips DVDR3440H DVD Recorder/HDD...
Digital audio problems
Try using a different cable for starters, regular rca, another optical or coaxial. If the optical works, then its a cable problem. If the coaxial works(and another optical doesnt), then its a cable/jack problem. If the RCA works(and the rest don't), then its a problem with the digital output. Try blowing into the holes, and if nothing works and you can't find any other advice, contact Pioneer. Good luck
Mar 11, 2006 | Pioneer DVR-5100H DVD Recorder
LG RH1999H DVD Recorder/HDD Recorder Logo
56 people viewed this question
Computer Repairing
Computer Repairing
