Question about HP Televison & Video
HP ID5220, rear projection 52'' HD TV won't power on.
I hold in the power button and the blue light blinks really fast, but as soon as I let go, there's a click and it shuts off. The TV doesn't power on.
SOURCE: green light blinking
start
Posted on Jun 30, 2008
SOURCE: JVC HD-52G787 52-Inch HDILA Rear Projection won't turn on
My tv wont turn on. It tries to turn on the green light lights up 3 times then nothing. what is wrong?
Posted on Jun 18, 2009
  • 47 Answers
SOURCE: 52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Posted on Sep 19, 2009
welcomejee
  • 10594 Answers
SOURCE: blinking power light
Power light blink 3 times shows that convergence out ICs got defective and need to be replaced.
If you are handy with electronics stuff repair and can solder parts in circuit board with proper tools then replace two big black ICs, convergence out, mounted on aluminum heat sink.
Or call local tech to fix it.
Let me know if you have additional question.
Thanks.
Posted on Dec 23, 2009
SOURCE: I have a jvc hd
i have a jvc hd 61g887 tv the lights keep blinking blue and red and won't come on
Posted on Jun 24, 2010
TV won't turn on - the front blue power light and red lamp light blink. Does this mean the lamp needs to be replaced?
Yes.The tv projection lamp inside the tv right now it is been inside the tv like a 1 1/2 or 2 years already.The tv been on daily and in used like 4 or 5 hrs tv watching daily?Yes,than the tv projection lamp life are ending and the causes.
May 08, 2011 | JVC HD-52G886 52" Rear Projection HDTV
Sony HD Projection TV KDP-57WS550, timer light blinks 5 times and repeats sequence. When power button is pushed sound comes on briefly, no picture, then TV goes off. Please advise.
Mine did this after a power flash. Lights blinking 5 or 6. They blink fast lol. I have sound till tv powers back down. Front yard bond fire? Or any ideas? Thx.
Dec 25, 2010 | Sony Grand WEGA KDP-57WS550 57" Rear...
My 52' HD television will not turn on, it is a JVC HD-52G887. The blue light comes on but there is no blinking red light. Please help
unplug the tv, then reinstall the bulb,if that doesnt work youll need a tech to help. (dont buy another jvc tv)
May 19, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Apr 09, 2009 | JVC HD-52G787 52" Projection Television
Dec 23, 2008 | JVC HD-52G787 52" Projection Television
JVC HD-527575 problem
We just had the same problem. The Projector lamp is burned out. You can get the lamp at Electrified.com. Their phone # is 800-678-8585
Oct 10, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Blue light in the front blinking no picutre no sound
This is the shutdown code for the lamp ballast. I would have a technician verify ballast is bad and replace. This can be a tricky repair for a novice because installation of the ballast requires that you remove the light engine. Hope this helps.
Mar 28, 2008 | JVC HD-52G886 52" Rear Projection HDTV
TV not turning on
This is the lamp error code. The lamp part# for your unit is
TS-CL110U. Hope this Helps.
Mar 21, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
878 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
