Question about Refrigerators
Water is dripping on top shelf. it is coming out of the 2 square holes
    President:
  • 1,136 Answers
Hi, The defrost drain behind the rear freezer panel is plugged. Remove the rear panel and clear the ice away from the drain. Then you will need to flush the drain hole with hot water to make sure it is open.
Some models require an after market drain heat kit.
Please get me your model # and I can look this up to let you know if you need that heat kit.
Thanks
Vic
Posted on Jul 11, 2009
Lg refrigerator leaks water inside
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
Sep 28, 2017 | LG LSC26905TT Side by Side Refrigerator
I have a Kenmore Model 60192000, freezer on top and no ice maker. Have a leak on left side over top shelf. It is coming from apart in the refrigerator above the shelf, has kind of a square neck. I do I...
Is it a leak or a drip? A leak means you have continuous running water and a drip is more inconsistant.
I would suspect that you have a drip, that is caused by your cooling tube having frost or ice buildup in it, which is quite common for some units. The fix that seems to work the best is to defrost your unit, making sure the cooling tube is completely free of ice and frost by blowing hot air from a hair dryer down it. Then cutting a piece of bare electrical (solid core) wire that will fit down the tube but not extend past the opening. Then you form a hook and put it around your defrost heater.
That way the heat from the defrost heater will be transferred down the wire and keep the tube free of ice and frost.
Jul 28, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
Water is leaking inside of the refrigerator on the (if you are looking into the fridge) the left side. I cannot tell where it is coming from - i see no dripping from anywhere but it sits in puddles on the...
I have a Whirlpool Top-mount refrigerator. Whirlpool also manufactures many of the Kenmore refrigerators.
A few weeks ago I noticed a puddle of water on the top right shelf in the refrigerator section. I figured out that it must be the water that forms during the defrost cycle and normally drains down through a tube in the back into an evaporator tray beneath the refrigerator. Something was preventing the water from draining away and instead it was dripping through the overflow holes from the freezer into the refrigerator section.
I emptied the freezer and took off the back panel. It actually wouldn't come off at first because all the water beneath the defrost heater which should have been draining out the drain hole was frozen into one solid block of ice. I used a hair dryer to melt the ice (took a while - be patient) and then took off the panel.
To melt all the rest of the ice in the drain tube I used the hair dryer. To clear out the ice in the drain tube, I used a turkey baster and kept putting down hot water until I heard water making it down to the evaporator tray beneath the refrigerator.
The following mod is "try at your own risk" (I wouldn't do this if you still have warranty coverage - call a tech instead):
I made this modification to prevent the problem from recurring (at least that's the hope): Wrapped a piece of wire (unbent a large paper clip) around the defrost cycle heater and stuck it into the drain hole. The theory is that the wire will heat up every time the defrost cycle runs and will keep the drain hole from freezing shut.
One thing I noticed during this repair concerns the drip pan beneath the defrost heater in the freezer (this is the pan that collects the water that is melted off the coils during defrosting). The drip pan does not seem to be angled properly so that the water will drain normally towards the drain hole. I guess water could remain behind then freeze later. I reported this to Whirlpool.
Mar 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Fridge is dripping directly onto top shelf. It is
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curtain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you have any other question. Mike
Oct 22, 2009 | Frigidaire FRT18FS6C Top Freezer...
Water is collecting on the top shelf.
You will have to empty your fridge and remove the back panel.clean it out by pouring warm water mixed with Baking soda into the drain at the back of the freezer compartment and let it drain into the drip pan at the bottom of the refrigerator. In the refrigerator section, find the screws that hold the control console securely to the roof of the refrigerator. Usually there are two of them towards the front. The front part of the panel will drop down and then you will see a plug to separate so now you can remove the entire control panel and sit it on the floor or kitchen table. Now you will see the hole going into the freezer section and the other hole going to the defrost pan under the refrigerator. I am suspecting the tube on the rear of the console which is on the floor or the table right now is either cracked or not fitting snuggly in the hole at the rear of the refrigerator. If you do not find any cracks, take some putty and wrap it around the end of the tube and then reinstall the console/control panel making a secure and tight fit into the hole.
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
STANDING WATER ON TOP SHELF
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
