Question about Sony Televison & Video
My KDL-40VL130 turns off with 13 blinks
I have a KDL-40VL130 or KDL-46V3000 (Same tv, different size.)
Worked perfectly, now when i turn it on the screen shows the picture for about 2 seconds, then it shuts off and the standby LED blinks 13 times, then pauses, then 13 times, over and over.
Any help would be great!
-Mike
    Sergeant:
  • 256 Answers
Check filter caps in power supply.
Posted on Jan 02, 2018
    Top Expert:
  • Sony Master
  • 49,110 Answers
Failing power supply
mfspencer
  • 58 Answers
SOURCE: please help
That is the blink code for the lamp ballast. Here is the more complicated explanation from the service manual.
IC2301(pin11) detects the error of LCD Power C.B.A. and Lamp,
then indicates the error when an inner malfunction of LCD Power
C.B.A. occurs, the Lamp voltage becomes more than 130V or
less than 30V, Lamp current becomes more than 5A, or the Lamp is blown
Hope this helps.
Posted on Apr 03, 2008
Slinteriors
  • 8617 Answers
SOURCE: 8 Blinks; Sony KP65WS500
8 Blinks means problem with audio is making set go into protective shutdown Check Audio Amp IC406. You can also make this appear on your screen to show how many times this has occurred or if any other faults are present by pressing the following buttons DISPLAY,CHANNEL,5,VOL MINUS,Then POWER. Hope this helps if you need anything further let me know
Posted on Jan 08, 2008
Slinteriors
  • 8617 Answers
SOURCE: Trouble code: Standby LED blinks 9 times
Try pushing the buttons on the remote and let me know what comes up on the screen if anything.
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
Posted on Jan 13, 2008
experttv
  • 203 Answers
SOURCE: Sony SXRD Projection TV
The 4 blinks is a fan error and if you ordered the correct fan then yes it will fix the problem. The most common fan to go bad in this model is the lamp fan (from the back its the big one on the left) I have seen other fans cause this problem from time to time though. the correct way to find out what fan is causing the problem is when the set is acting up you need to take some voltage measurements on a plug on the back board (this requires removing the back) . Missycam70 unfortunately the service man was correct if he came out and the set was working there would be nothing he could do. you have to look at it from his side, if he came out and put all new fans in it and then the problem was the ASU/DSU (fan control board) then he would look like an idiot and have to fix you set again and most likly lose money on the deal.
Posted on Sep 11, 2008
SOURCE: sony projection tv kp-57wv700 please help!!!
Follow these instructions:
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
They have fixed dozens of tvs with this problem, including mine.
Posted on Dec 20, 2008
Sony tv model number KDL-40W600B with total black screen. Not getting any picture at all, including the loading screen and no sound.
Is the TV showing that it has power? Try connecting to a different source. How old is the TV? It could be that the chipset has malfunctioned, the LCD panel or Digitizer is damaged, if that is the case, sadly it is often cheaper to buy a new TV than it is too fix them. Good Luck!
Dec 04, 2016 | Sony Televison & Video
Tv guide doesn't work anymore
I have a Sony model KDL-32BXR6 that the TV Guide first showed no listings this past weekend. Last night when I entered the Guide the screen displaying the Setup/Display Setup Progress came up stating "In Progress". Same thing this morning. Something must have changes with the input signal if this occurred with two different sets.
Dec 04, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My sony bravia kdl-46v3000 was giving me three blinks i change the main board now i am getting eight blinks
try this.
Turn on the TV. While holding down V on the remote control, press POWER
on the TV. (The TV will turn itself off, then back on again.) Release V.
WARNING: The Reset will clear all of your customized settings
Sep 27, 2012 | Sony BRAVIA KDL-46V3000 Television
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
My flat screen tv shuts off and standby led blinks 13 times.
Our $2700 less than 3 year old Sony LCD KDL-40XBR5 did the same thing 2 weeks ago. Sony was anything but helpful. They said to take it to a repair shop or we could send them $550 and they would replace it with a $800 set. Repairman says that it is a panel and the part has been discontinued by Sony. The 46" sets had the same problem and were recalled but not the 40" screen. We stopped on the way home and purchased a 40"
Jul 12, 2010 | Sony KDL-40XBR4 40 in. LCD HDTV
Flashing red led.
This is a very common problems with LCD and Plasma tvs.The power supply board have dead leakagas capacitors.These dead capacitors they alway bulges up on it tops or puff up on it tops.U know basic electonic's and soldering take the tv aparts searches all around the power supply board,that the board where the power a/c cord conected to it.Replaced these dead leakages capacitors,ur tv will power up again and work.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 17, 2010 | Sony BRAVIA KDL-40V3000 Television
Sony Bravia KDL-46V3000 turns off with blinking front light.
Sounds like the power supply may be failing. Count the beeps next time, that will give you the error code.
Jun 18, 2017 | Sony BRAVIA KDL-46V3000 Television
No sound or picture when turned on
what does the tv do when you turn it on does the front light blink?or does the tv power up but sound and pic are absent?
Feb 28, 2010 | Sony BRAVIA KDL-46V3000 Television
Sony kdl-40v5100 has handshake problem
1.This issue sounds as though the TV connection circuit has an issue.
2. You have changed the DVR and the HDMI cables and you still have an issue with the video (pink screen) indicates a video circuit issue ( improper voltage or current) at the video section of the circuit.
3. This will require some troubleshooting by a qualified tech.
4. To make sure, try connecting another properly working LCD TV to the cable box or DVR an check.If you get a picture and sound properly it is the TV.
5. Usually a cable box is QA'd (quality assured) by the company and will not be sent unless tested 1st
Feb 05, 2010 | Sony Bravia KDL-40V5100 40 in. LCD HDTV
Televison & Video Logo
313 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
