Wireless network card only provides mac and sn number but re added the os and wiped the driver. Please hlep find the corret driver.
SOURCE: need help with my laptop going wireless without a network
A wireless local area network, which is the linking of two or more computers without using wires. you cant use just one computer...the laptop needs a signal from another computer.
SOURCE: no drivers for wireless lan
** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
folder to another folder and restart Orbicam program.
If that does not work then do this:
Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
"Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
SOURCE: wireless internet is not connecting
dear,
Pl check with your modem wirless port is active or not samething in to your laptop and desktop.
after connection pl give your modem ip range and search for wirless device.
Regards,
Ravindra Shah
SOURCE: problems adding a vista computer to a mn-700 network
you need to install a driver in your vista which will enable you to print your files.i hope this helps
SOURCE: Network Adapter driver conflict
The Yellow mark means that the device is not properly install or the drivers are missing. i would search for the drivers using another computer download and install them to get to on the net.
What is the mac and sn of the network card?
