Question about InFocus ScreenPlay 7205 Multimedia Projector
Premature lamp replacement message
I am getting a "change lamp" message with only 375 lamp hours used. The message appears and dissappears intermittently.
The beamer is mounted to the ceiling and is always allowed to completely cool off. Picture quality is still excellent. I am not using the high power setting.
I have removed the lamp and cleaned the connection. But this has not solved the problem. I have reset the beamer back to the factory setting which also did not solve the problem.
Is there any advice you can give me?
  • 2 more comments
  • Anonymous Apr 27, 2008
    Hi, I just recently purchased a Sp 7205, and I get a Replace Lamp massage with 151 Lamp Hours.. I tried the reset option and everything, but the massage would just appear again...
  • giles466 Jan 03, 2009
    I have a SP 7205 projector and I have just got the Replace Lamp message after 680 lamp hours. I tried the resetting the lamp hours but to no avail. Projector brightness is still excellent.
    I am going to try to do a firmware upgrade (mine is currently at 1.8, the latest is 2.4), and also take the lamp out and put the same one back in again.
    If anyone has any solution though please let me know.
  • Thomas Ljunggren
    Thomas Ljunggren Oct 01, 2013
    I do have the same error, anyone any ide? i guess heat problems, fans to slow,
  • Thomas Ljunggren
    I have the same error, tried with 2 lamps. Anyone any ide how to fix?
  • 34 Answers
You need to reset it in the menu options.
Posted on Dec 05, 2007
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
How to reset lamp hrs.
you can reset the lamp hour by the following settings
1.Power on the projector
2.Press the EXIT button on the projector for 3 second to display the total used lamp time
3.Press the MENU button on the projector (adjustment message will appear
4.Press the LEFT ARROW or RIGHT ARROW button to to reset the lamp hour
5.Press the EXIT button
Jan 18, 2011 | BenQ PB2220 Multimedia Projector
A message appears when the set (LCD) is turned on whichstates that the lamp should be replaced but it is workning. Replaced the lamp 11 months ago and it has a 1 year warranty. What is the purpose of the...
that lamp timers are only there to give you an idea that the lamp may fail soon. the tv will count to a certain number of hours and then give the message on screen. most tvs the number will be around 4000hours or so. i suggest using the tv until the lamp fails you may change a lamp that has many many many more hours when you dont need to. there is a timer that you can reset if you consult your owners manual so the message will not show up any longer.
Dec 23, 2010 | Panasonic PT-61LCX65 61" Rear Projection...
My jvc 56' flat screen is showing a message in blue to replace lamp but there still is a good picture?
Well, the message is trigger by the passing of time. The TV simply counts the hours the TV has been on, then when the counter hits the designated amount... the message starts to appear. Best thing to do is order a lamp and have it on hand. You can go into the TV menu and reset the lamp timer for now, just to get the message out of sight. When the lamp does fail, change the lamp and reset the timer again. I hope this was of some assistance, best wishes.
Apr 12, 2010 | JVC HD-61Z886 61" Rear Projection HDTV
Hi, My Infocus screenplay 5700 gave a message to change lamp, but after turn it off and then on, i kept working good, after an hour suddenly turned the lamp off but the fans kept working. Now when I try...
the lamps are good for about 2000 hours. but it sounds like it's time to get a new lamp. but after you put it in, go into the menu and reset the lamp timer.
Dec 10, 2009 | InFocus ScreenPlay 5700 Multimedia...
Bad Lamp Call FOX 1-800-227-5369 Lamp number is
BP96-00608A or BP96-00826A $109.00 Mats Electronics is another company for Lamps 1-800-628-1118 or Find one on E-Bay
Nov 30, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
With all menu settings appearing with their normal values, my X2 projected image ''oscillates'' between showing correct colours and a heavy green overcast with no blues or whites. The green light is steady...
your colorwheel is going bad. needs replacment. find an infocus service center and purchase part # 525-0144-00. shouldn't be more than $50, but replacement is pretty involed. you need to remove the top case, front and back covers, power boards, plate, lamp house assembly, and fans just to get to where the colorwheel is plugged in to the main board. removal of the actual colorwheel is only 3 screws.
Jul 30, 2009 | InFocus Office Equipment & Supplies
Need instructions for lamp unit part number TY-LA2004
the projector will not know that u have replaced the lamp!u will have to tell it that a new lamp has been installed
to do this go to the menu & find reset lamp hours option & do a lampo reset.the lamp hours will reset to zero & then the replace lamp message will nt appear!
Jan 28, 2009 | Office Equipment & Supplies
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Reset the bulb
1-press the exit button on the projector for 3 second to display the total used lamp time.2-press menu button on the projector during the lamp hour message- an adjustement message will be appear press right or left arrow to reset timer to zero.if success osd change to(lamp hour reset ok!)
Jan 12, 2008 | LG RD-JT91 Multimedia Projector
InFocus ScreenPlay 7205 Multimedia Projector Logo
206 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
