Hot air blower does not opperates
Hot air blower stop moving
    Champion:
  • 233 Answers
Assuming this is a central heater, it could be the motor or the control circuit from the board shutting it off. The motor needs to be checked for voltage when calling for operation, voltage w/ no operation= replace motor and capacitor
no volatgage means replace component that controls motor
Posted on Jul 12, 2009
My 1995 ford fairlane's climate control stopped working after i got my transmission replaced. It just blows hot air. Does anyone kmow what coild be the reason.
possibly the hot water cut off valve, that is the only thing that may have been messed up during that process
it is located near the back of the engine and stops coolant flow through the heater core during ac opperation
Mar 18, 2015 | Ford Fairlane Cars & Trucks
I have a 1999 jeep grand Cherokee limited edition my heater only throws out cold air why is that?
this is easy. (are you moving or parked) ill assume stopped.
first is the blower working, (seems so)
ill guess that no heat in all vent modes, and re-circ, on.
next is the engine fully hot, hot means at 180F or more holding
(we measure it with a pyro gun)
next, are both heater core hoses hot/ at the fire wall? and equal at 180f?
yes, good. then the damper is stuck closed i the heater box.
no , then there is heater core blockage. (skipping every 2 year flushes are you, sure...)
it only takes 2 things
hot water ,p[assing through the heater core
and air passing through its fins to get hot cab air.
just 2.
Nov 14, 2014 | 1999 Jeep Grand Cherokee
My heat not blowing or coming out hot at all
fan motor or relay is bad check relay first swap out with another one in the distribution box if it still doesn't blow check blower for loose connection an is there power at blower motor if there is replace motor,if air is coming out but just not hot check to see if controller on dash is moving the door in the air box move controller from hot to cold and listen under the dash to see if you hear the door closing sometimes you can nkock on the box and it may move if it is stuck after that you may need to see a shop,also make sure heater hoses are getting hot under the hood they go into the firewall ther is two of them placed close together make sure both are hot
Dec 11, 2013 | 2005 Chevrolet Impala
My 2005 chevy avalanche only blows cold air until i drive then when I stop cold air Agian
One of two things has happened. Either your coolant has gotten really low (easy enough to check) or you heater core is starting to plug up.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Oct 14, 2012 | 2004 Chevrolet Avalanche
Air conditioner
You are saying the blower motor stops when the truck stops moving ?
Or the blower motor doesn't work and the only air you get thru the vents is outside air when the truck is moving ?
Jul 19, 2012 | 2002 Chevrolet Suburban 2500
What is the proper settings for the blower motor on a newmac hot air wood furnace
hot air is lighter and requires less cfms to move it compared to your cooling air. It should be set to low or med low speed depending on how far you have to move the air
Dec 11, 2009 | Honeywell Heat/Cool Thermostat
Front Blower
ok, missed the part about the rear ac working, the part that causes this is called the air temperature control blend door actuator motor, it is an electric motor driven gear drive that moves the plastic door inside the air ducking to mix or shut off the hot or cold air from the ac evaporator core or the heater core, you will need to replace it.
Sep 03, 2009 | 2002 Dodge Durango
2000 Cherokee Heater only works once the vehicle is moving
this is normal, heat comes from your motor so it isnt hot enough until you start working the engine
Nov 20, 2008 | 2000 Jeep Cherokee
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
