I can not open it with the key remote, also i need to know where is the fuse located for the trunk. Thanks
Have helper push button as you try to lift trunk open. I may just be weatherstrip is sticking. Use silicone spray lube on rubber to stop this. If latch has failed may be harder. Does the trunk have a key hole? Often when electric latch has failed you can turn key, then push button or other release mechanism and then turn key further for manual release (some cars--not all).
Testimonial: "Good answer, but the open button inside the glove compartment don't work. When i press it, I hear a click click sound."
REMOTE TRUNK LID RELEASE - IF EQUIPPED
You can open the trunk from inside the vehicle by
pressing a switch located inside the glove compartment if so equipped. (it is optional)
