Question about Lisle Serpentine Belt Tool
Where is the serpentine belt tensioner bolt located on the 2002 porsche boxster? I replaced the alternator, got the belt off by removing alternator bolts first then popping of belt, but I cant get it back on as I cant find the tensioner to loosen it.
The tention could be just a spring loaded pulley in the pattern of your s-belt check your pattern sone where on your car under the hud.
Posted on Jul 11, 2009
I am trying to hange the serpentine belt on my 09 lancer rallyart and it keeps slipping off
Locate the two belts on the left side (passenger side) of your Mitsubishi Lancer. The outer belt is a serpentine belt, operating four pulleys and the inner belt is your alternator belt.
  • 2 Follow the serpentine (outer) belt to the three pulleys lined up vertically near the front of the engine compartment. Locate the middle pulley, which is the tension pulley for the belt.
  • 3 Loosen the bolt on the middle pulley with a socket wrench by turning counter-clockwise. Do not remove the bolt, just turn it a couple of times. Loosen the tensioner bolt on the side of the of the pulley, facing the front of the vehicle.
  • 4 Remove the serpentine belt and then loosen the bolt on the alternator. With the alternator loose, move it forward so that the alternator belt loosens up and then remove belt from the pulleys.
  • 5 Install the new alternator belt by placing it over both inside pulleys. Tighten the tension on the alternator belt by moving the alternator back and keeping tension on it by holding it back with a long screwdriver. While the alternator belt is tight, use a socket wrench to tighten up the bolt on the alternator.
  • 6 Place the serpentine belt back on the pulleys and then use a socket wrench on the bolt on the front of the tension pulley. Once the serpentine belt is tight, tighten up the bolt in the middle of the tension pulley.
  • 7 Start the Mitsubishi Lancer's engine to test the alternator belt and make sure it is working properly. Once you have verified it is working, turn the engine off.
  • Oct 25, 2011 | 2008 Mitsubishi Lancer GTS CVT Sedan
    How do I remove an altinator from a 2004 ford escape.
    Hello there,
    To replace the alternator in your car:
    Open the Escape's hood, and examine the belt-routing diagram on the fan shroud. This will show you the location of the alternator and the serpentine belt tensioner.
    Pull the serpentine belt tensioner away from the serpentine belt with the serpentine belt tool far enough to allow you to dislodge the belt from the alternator pulley with your other hand.
    Unplug the wiring harness from the back of the alternator by hand. Remove the ground harness from the alternator with the socket set.
    Unbolt the alternator from the alternator bracket with your socket set. Lift the old alternator out of the bracket by hand.
    Compare the old alternator to the replacement alternator before installing the replacement. Make sure they're both physically identical before continuing. If not, take them both to the parts store to match up a proper replacement.
    Set the replacement alternator in the alternator bracket by hand. Bolt it in with the socket set. Plug the wiring harness in by hand and bolt the ground harness to the back of the alternator with the socket set.
    Install the serpentine belt on the replacement alternator in reverse of how you removed it from the old alternator.
    All the best. Elect_Comp
    Sep 13, 2011 | 2004 Ford Escape
    Remove and replace alternator
    Just follow these steps to remove and replace the alternator. You will need this tools, Serpentine belt tool, Battery wrench, Lug wrench, Floor jack, Jack stand, Socket set,
    1. Open the hood, locate the serpentine belt tensioner and move the tensioner off the
      serpentine belt with the serpentine belt tool. Slip the belt off the tensioner
      pulley with your other hand and then slowly move the tensioner back to its normal
      position. You can pinpoint the location of the belt tensioner by following the belt
      routing diagram, printed on the fan shroud.
    2. Disconnect the negative battery cable from the battery with the battery wrench.
      Push the cable end away from the battery so it doesn't make contact during the
      repair.
    3. Turn the lug nuts on the right-front wheel counterclockwise until they're loose
      enough for hand removal, but leave them on for now.
    4. Lift the right-front end with the floor jack and support it on a jack stand placed
      underneath the right-front frame. Remove the lug nuts and right-front wheel by hand
      and set them aside.
    5. Slip the serpentine belt off the alternator pulley by hand. You can access the
      alternator through the wheel well. Unplug the wiring harness from the alternator
      by hand and remove the ground strap with your socket set.
    6. Remove the alternator mounting bolts with your socket set. Lift the alternator out
      of the engine well, through the wheel well. Insert the new alternator in reverse of
      how you removed the old one.
    7. Thread the alternator mounting bolt through the new alternator and into the
      alternator bracket by hand. Tighten the bolts with your socket set.
    8. Attach the alternator ground strap with your socket set. Plug the alternator
      wiring harness in by hand.
    9. Slip the serpentine belt over the new alternator pulley. Reinstall the wheel and
      lug nuts by hand. Lower the Taurus of the jack stand with the floor jack.
    10. Move the belt tensioner aside again and place the belt on the tensioner pulley with
      your free hand. Hold the belt on the pulley and slowly move the tensioner back to
      its normal position. Reconnect the negative battery cable to the battery.
    Hope this helps you.
    Take care and good luck
    Jan 08, 2011 | 2002 Ford Taurus
    How to replace alternator
    Remove the negative battery cable from the battery.
    2. Loosen the right front wheel lug nuts.
    3. Jack up the automobile and place jack stands in appropriate positions. Leave room to access the alternator from underneath the car.
    4. Complete removal of the right front wheel.
    5. Remove the right front lower splash shield.
    6. Release tension on the serpentine belt at the tensioner.
    7. Slip the belt off of the tensioner and the alternator.
    8. Attach an engine hoist at the front of the engine. This is a transverse mounted engine and the hoist will need to be attached near the engine mount located at the right front fender inner fender.
    9. Remove the top portion of this mount.
    10. Loosen the rear engine mount at the firewall. This mount is slotted and will permit you to pull the engine forward toward the right front corner of the engine compartment. This will give access to the alternator.
    11. Remove the two bolts that attach the serpentine belt tensioner and remove the tensioner.
    12. Remove the top alternator mounting bolt. Do this from the engine compartment side.
    13. Remove the lower alternator mounting bolt. Do this from underneath the car.
    14. Turn the rear of the alternator up to access and remove the electrical leads.
    15. Remove the alternator from the engine compartment.
    16. Install the new alternator in the REVERSE ORDER.
    hope this helps if it does please give a thumbs up rateing thank you have nice day
    Dec 28, 2010 | 2002 Saab 9-5
    Replace alternator belt
  • Locate the two belts on the left side (passenger side) of your Mitsubishi Lancer. The outer belt is a serpentine belt, operating four pulleys and the inner belt is your alternator belt.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • Oct 08, 2010 | 2002 Mitsubishi Lancer
    2002 Porsche Boxster - had squealing coming from
    Mine did that off and on for a month with no other problems then it started making a loud suction noise and the check engine light came on. I took it to the dealer and they said the "oil separator" needed to be replaced.
    After the repair I never heard the squealing again.
    Apr 21, 2010 | 2002 Porsche Boxster
    Do you have step by step instructions on how to change out an alternator on a 2002 Chevy S-10 with a 4.3 liter engine ( 4wd if that matters ). THANKS
    Not specific to S-10 truck, but here you go.
    Before you start, you might want to make a sketch, or take a couple of digital photos of alternator wiring and belt routing to make reassembly easier.
    Disconnect negative (-) battery cable from battery.
    Find serpentine belt tensioner pully. Should be a square hole in arm that holds that pulley. Insert a 3/8" socket wrench or breaker bar into hole to remove tension on belt.
    Remove belt from alternator pulley.
    Diconnect all wires from the rear of the alternator.
    Remove alternator mounting bolts, make note of order and location of any nuts/washers/spacers.
    Remove old alternator.
    Installation is reverse of removal.
    Dec 16, 2009 | 2002 Chevrolet S-10
    if you have managed to replace alternator then i recon you have routed the belt wrong, also make sure alternator pulley is same size as old one
    Jul 05, 2009 | 2002 Porsche Boxster
    Porsche boxster alternator belt
    some porsches adjust belt tension by adding or removing shims between the two pulley halfs.take the nut off the pulley insert the belt put thebelt,outer pulley and nut back on.
    Jul 05, 2009 | 2001 Porsche Boxster
    Altenator
    Unplug the alternator remove ground to motor.
    Remove serpentine belt.
    remove 2 bolts which hold alternator.
    replace reverse of removal.
    4 out of 10 difficulty.
    Only special tool you will need is a wrench long enough to pull back the tensioner.
    See the radiator support for location of tensioner and serpentine routing.
    While its off, i would suggest replacing the belt too.
    Dec 26, 2008 | 1999 Ford Windstar
    Lisle Serpentine Belt Tool Logo
    114 people viewed this question
    Top Lisle Hammering Experts
    Robert Wooley
    Robert Wooley
    john h
    Lawrence Oravetz
    Are you a Lisle Hammering Expert? Answer questions, earn points and help others
